Technical stuff => Engine => Topic started by: Lancia Beta 2000 on October 04, 2010, 02:12:52 PM
Title: thrust bearing
Post by: Lancia Beta 2000 on October 04, 2010, 02:12:52 PM
Hi guys,
who sells a new thrust bearing for a carb'd beta 2000?
do you know if is the same bearing of other fiat cars?
Clutch disc and pressure plate are the same of fiat 124, alfa 155 etc..
thank  you  :)
dan
Title: Re: thrust bearing
Post by: WestonE on October 05, 2010, 07:25:51 PM
Dan
Guy Croft sells them and they are on ebay as they are the same as 105tc 130tc 131 and 130 Fiats. They come in standard sizes and oversizes, but it is rare to need to replace them so check the crank condition carefully.
Post by: Lancia Beta 2000 on October 06, 2010, 12:35:31 PM
Thank you Eric.
The clutch is rare to need to replace or the bearing??
Because my car, "squeals" when clutch pedal is pressed..so I think that it's the release bearing..
The car (and the clutch) had 110.000 miles..
Post by: WestonE on October 11, 2010, 07:53:25 PM
Ok
I miss-understood I thought you meant crank thrust bearings. You can buy Clutch release bearings from The Monte Hospital and an uprated clutch if you want one and the clutch arm nylon bearing. I would always replace the release bearing with the clutch.
Post by: Lancia Beta 2000 on October 16, 2010, 10:40:56 PM
Thank you Eric..
Sorry that I don't say Clutch thrust bearing  ;)
I'll buy the montehospital bearing As soon as possible;
Now unfortunately I have some (think big) problems with the differential unit, but I will write next days in the Transmission subforum, to talk with you about possible solutions..
Hy guys,
Dan
