Technical stuff => Engine => Topic started by: hongkongphooey on February 17, 2010, 10:58:35 PM
Title: Intake ports and valves....
Post by: hongkongphooey on February 17, 2010, 10:58:35 PM
As a matter of interest,how finished are the standard intake ports in the head,and do the valves have slightly wasted stems?
I ask because i've had the intake manifold off and the ports look like they've had work and the intake valve stems are slightly wasted.
Title: Re: Intake ports and valves....
Post by: hongkongphooey on February 21, 2010, 11:15:55 AM
Has nobody had a head apart then?  ???
Post by: 75coupe on February 21, 2010, 11:29:55 AM
I have had a few heads apart, and can tell you that the stems are not normally wasted. The port finish is a cast finish with a line (casting mark ) running through the centre line of the port where the sand cast forms meet. Are the valve guides still protruding through into the port? Do you have a pic? I'll see if I can take a pic of a std head.
Post by: 75coupe on February 21, 2010, 12:05:04 PM
Sorry I got that wrong, the inlets are very slightly wasted stems, just below the guide......
Post by: hongkongphooey on February 21, 2010, 05:41:52 PM
Yeah that sounds about like mine....the ports however don't have any casting lines,just fine circular lines that look like they have been made by a flap wheel or something. The guides have not been touched by the looks of things.
Post by: WestonE on March 10, 2010, 07:43:55 PM
Hong Kong
Have a look at Guy Croft Racing Engines website there are lots of pictures of tuned and ported components so you will be able to spot 3 angle valve seats and real performance cams.
Post by: hongkongphooey on March 11, 2010, 08:50:26 AM
Thanks Eric....i'll do that.
