Technical stuff => Body => Topic started by: Nigel on February 04, 2021, 06:25:18 PM
Title: Windscreen surround
Post by: Nigel on February 04, 2021, 06:25:18 PM
Hi all,
I have a brown mark inside the screen that is in front of the inner trim.
Has anyone else had this, and did you find a remedy other than removing the glass?
Nige
Title: Re: Windscreen surround
Post by: peteracs on February 04, 2021, 06:57:24 PM
Hi Nigel
I think you will find it is rust mark going into the laminate of the glass, solution is, I fear, replace screen.
Post by: Nigel on May 13, 2021, 04:45:00 PM
Peter,
I should have acknowledged your reply earlier.....
Thanks for that. Can you tell from these pics whether I have a bonded or rubber-mounted screen?
My rear window trim appears identical....and I want to remove just the trim for rust repairs.
A previous reply from Ian [Squigly] suggested the 'dental floss' method, I assume using a thin wire thingy.
Post by: peteracs on May 13, 2021, 05:43:11 PM
I have never seen a rubber mounted one, so all I can add is if the metal cover plate is bonded in then the screen will be bonded. I am not sure if the rubber ones actually still have the metal surround?
