Technical stuff => Interior => Topic started by: GerardJPC on January 19, 2021, 08:46:19 AM
Title: Should the clock in a pre facelift Coupe light up?
Post by: GerardJPC on January 19, 2021, 08:46:19 AM
Dumb question alert!  1978-79 car with pre facelift interior.  The clock located in the wooden panel with all the knobs on it works but does not light up.  Is it supposed to?  If so, I foresee swearing ahead as I try to access the bulb.
Title: Re: Should the clock in a pre facelift Coupe light up?
Post by: Neil-yaj396 on January 19, 2021, 09:25:14 AM
The pre-facelift saloon clock that I have in my stash has a bulb holder, so presume the same for the Coupe? Isn't the wood effect panel holding the clock just held in by 4 thumb type screws? Much easier to get at than the facelift clock!
Post by: peteracs on January 19, 2021, 09:54:34 AM
Hi Gerard
Yes, it should be linked to the side light circuit as per other lamps on the centre section. It is a simple pull out holder and the lamp is a small baynet type bulb. Access should be possible via the speaker grill on top of the dash rather than trying to get at it from the centre section.
Post by: GerardJPC on January 19, 2021, 05:58:01 PM
Cool, thanks all!
