Technical stuff => Suspension => Topic started by: lukasdeopalenica on January 07, 2014, 03:44:48 PM
Title: Refurbishing of axle stubs
Post by: lukasdeopalenica on January 07, 2014, 03:44:48 PM
What method should be the best to refurbish the stubs? After blasting I am thinking about two options - powder coating (additional thickness - what with fitting of bearing on the axle?) or galvanic plating. Some of you has its own experience, so any tips are welcome :)
Title: Re: Refurbishing of axle stubs
Post by: MattNoVAT on January 07, 2014, 05:21:52 PM
I powder coated mine but I made up a set of plug/covers that covered the bearing holes.
Two round pieces of steel that were just wider than the bearing, a length of threaded bar, four nuts & washers.
I drilled a hole through the centre of the two round steel covers and then assembled the threaded bar/nuts so that the powder coat could be sprayed/baked on without affecting the inner face where the bearing slides in.
Sent from my iPhone using Tapatalk (http://tapatalk.com/m?id=1)
Post by: lukasdeopalenica on January 07, 2014, 10:32:24 PM
Matt, do you mean also the stub shaft, or the whole hub assembly? I dismantled the hub and the bearing.
