Technical stuff => Engine => Topic started by: Hawk on August 21, 2012, 04:45:27 PM
Title: Engine swap - anyone done it?
Post by: Hawk on August 21, 2012, 04:45:27 PM
I am toying with the idea of a second Beta and turning it into a bit of a 'sleeper'.
Tuning the standard engine is expensive and I quite like the idea of modern running gear and a V6.  I am pretty handy with the spanners and have a mate with a full workshop / engine hoist etc who is also a coded welder but have no idea how involved an engine swap would be.
Ideally I'd prefer something Italian (Alfa V6) but would be happy with a Ford or Vauxhall (or whatever) lump.  Would probably buy a complete car so would have the ECU, gearbox etc.
But I'm willing to stick pretty much anything in if it makes life a lot easier.
Anyone got any tips / experience of doing anything similar?
Title: Re: Engine swap - anyone done it?
Post by: dougdee123 on August 22, 2012, 05:18:27 PM
Well, if you've taken your brave pills for today, how about the engine and drive train from a Thema 8.32?
Advantages - There are still a few about.
                    It is beta ish somewhat so integrating it with the bits you want to keep should be possible.
                    It would have a definite kudos - Ferrari badges and all that.
Disadvantages - Engine repairs would set new financial standards.
                       It may well be a money pit. (nothing new there then!)
Doug
Post by: HFStuart on August 22, 2012, 07:11:57 PM
The only swap I've ever done is Fiat TC into rear engined Skoda - pretty simple as these things go.
To go in the front of the beta you'd want something fairly low and, ideally transverse.
I wondered about the Ford / Mazda V6. It's a wide angle V and fit beneath the bonnet of an MX-3 (1.8, 2.0 & 2.5 were all the same block) so it meets the criteria for low. And even in 1.8 form it produced 140bhp so no lack of go either. Plenty of them around from various Mazdas and the Ford Probe and of course they were all installed transversely
Challenging job - but not impossible.
Post by: Zagato on August 22, 2012, 09:33:15 PM
Vauxhall fitted a 3 litre V6 Diesel in the Vectra some years ago
.... they would be fairly rare mind
But bags of power ... and torque
And also an interesting engine sound
Reasonable economy too
Just an idea ... no idea if it would fit mind
Post by: Hawk on August 23, 2012, 08:52:36 AM
I'm doing an Alfa V6 into my HPE, slowly. The Alfa 156 is a cheap enough donor these days.
Oooh - tell me more.
Presume you are dropping the complete engine and gearbox in?  And that it fits in the engine bay?
Post by: peteracs on August 23, 2012, 08:03:46 PM
If you are looking for help on the Alfa V6 as a donor, though obviously not the same kind of install to a Beta, the guys over at stratosec.com have lots of experience with putting them into the replicas and the things to watch out for etc. Very friendly bunch with many years knowledge as the Alfa has been the choice engine since the 164 was around.
Post by: MattNoVAT on August 23, 2012, 08:25:41 PM
To be honest transplanting a V6 into a Beta engine bay is completely different to fitting a V6 into a Hawk Stratos, I've done it twice!  The Hawk chassis is easy to work on and does not need anywhere near as much "conversion" to accept the V6 unit or moving of heaters, fuse box etc, the Beta engine bay...... Different story altogether!!
The Stratos and the Hawk, which is the closest replica  by way of chassis design, was designed to take a V6 246 Dino power plant (even though they did try a prototype with a Fulvia V4) and the Beta was designed with the inline 4 cylinder in mind.
Just my 2 pennies
Post by: HFStuart on August 23, 2012, 08:54:44 PM
X1/9 ??
Post by: fulviafiend on August 23, 2012, 09:11:37 PM
This is how to fit an Alfa V6 into a Beta, not the easiest way but it does give easy access! ;)
Picture © copyright Lawrence Clift Photography
Post by: peteracs on August 24, 2012, 05:08:58 PM
Just my 2 pennies
Hi Matt
Yes, sory was not too clear on what I meant. The Stratos replicas such as Hawk do have various engine fitment options, so not an unknown as the Beta would be in general. I was really thinking along the lines of 'when you have fitted the engine in', the next phase I guess is hooking everything up, and that is where I saw the Stratos guys may be useful as there are often discussions on gear linkage etc, which is not necessarily that easy I guess (never tried anything like this, so can only imagine).
Impressed you have built 2 Hawks, do you still have any of them?
Post by: MattNoVAT on August 24, 2012, 05:48:10 PM
I've sold both my Hawks now the first went to Italy and had a Dino 246 engine installed instead of the Alfa 164 12v 3 ltr, the second one is still in the UK.
Being over 6 foot 4 inches tall I don't really fit in a Stratos, which was designed with smaller Italian types in mind ( Like Sandro Munari !)  It was an itch that has now been scratched and was a great car to have after the my years of owning Integrales because it was such an attention getter!
It was and still is a drop dead gorgeous car IMO:
Here you go...
Post by: mangocrazy on September 04, 2012, 11:36:58 AM
That Hawk/Stratos of yours (or ex-yours) is absolutely gorgeous. I've lusted after a Stratos replica after having seen the original on the RAC rally many years ago, and yours is/was absolutely spot on. Dare I ask how much it cost to build and how much you sold it on for? If you don't want to disclose, I fully understand.
Post by: peteracs on September 04, 2012, 03:16:22 PM
I also have a hankering to build one or at least own/rebuild a pre built for a while, being 5' 8" helps with the fitting into them, though I think the newer Listerbell can accomodate taller folk more easily.
Check out the Stratos Enthusiasts Forum here
www.stratosec.com (http://www.stratosec.com)
The general consensus is a new build with mainly new parts (apart from donor engine/gearbox etc) will be around £30k, used ones can be had for £20k-£33k+ and some may have been sold recently for as low as £15k, but have no first hand knowledge on that lower value. There are one or two available now should you be feeling flush!
Post by: MattNoVAT on September 04, 2012, 04:29:40 PM
One thing I would say is that it is not an easy car to build, you need lots of tools, lots of skill, lots of time and lots of money.  Nothing for a Strat rep is cheap and lots of parts are hard to find.
Post by: archigraphe on September 14, 2012, 01:06:35 PM
And why Not an integrale engine with conversion of the subframe for the passage of the exhaust?
This Engine seems to have same design , but tilt to front from 20° .
And why not an Integrale Beta ?
Post by: MattNoVAT on September 14, 2012, 03:14:20 PM
You would be better off using a Thema 16v Turbo Phase 3 with a LSD unless you make the Beta 4x4. (Painful)
Inlet / Exhausts are reverse design to Beta (exhaust is at the front)
Post by: archigraphe on September 14, 2012, 07:18:53 PM
Are the thema gearbox bolt on to Beta block?
Post by: oldspider on January 29, 2014, 05:31:34 PM
I'm glad the OP asked this, because it would be something I would want to consider myself!
If I could get a decent Spyder body and completely transplant the engine and gear box from something contemporary (doesn't have to be fancy). I'm thinking a newer Focus!!
I know this is like painting a moustache on the Mona Lisa, and I don't know if the fit is impossible, but I'd definitely like to know if such a thing has been done.
Post by: HFStuart on January 29, 2014, 07:37:35 PM
There was a chap on here a few months ago fitting a Jaguar 4.0 6 cylinder into a Beta! That was a rear drive conversion though.
I suspect a modern transverse installation would be even more challenging as the bonnet line is very low by modern standards.
Post by: slowe on February 02, 2014, 11:09:04 PM
I think the Jag 4.0 6 cylinder project has bitten the dust. I think he was trying to sell some of his lancia parts early last year.
