Technical stuff => Brakes => Topic started by: smithymc on July 07, 2012, 01:16:06 PM
Title: Rear caliper pistons
Post by: smithymc on July 07, 2012, 01:16:06 PM
Am on the rear brakes now. The Haynes manual calmly says 'screw piston clockwise into caliper' to gain clearance for new pads.
Any tips on how, what with and whether you need a gorilla to hold caliper and turn piston at same time?
Much bad language and skin loss in past half hour.
Thanks for any help.
Title: Re: Rear caliper pistons
Post by: MattNoVAT on July 07, 2012, 02:00:06 PM
Sometimes you need to screw them in and apply quite a bit of force so that the thread picks up and the piston starts receding, I've even had to tap gently with a hammer on the head of the piston on rare occasions because the piston has come out too far.
Post by: HFStuart on July 07, 2012, 10:51:23 PM
A piece of 6mm keysteel is just about perfect IIRC to turn the piston. As Matt says sometimes you need a bit of force too.
Post by: MattNoVAT on July 08, 2012, 07:15:41 AM
I use a tool that was originally meant for bolts that secured the anti-tilt plates for AS400 expansion racks ( computer kit )
But there are universal square block sockets that are about £7 from Halfrauds that make life easier.
Post by: Neil-yaj396 on July 08, 2012, 08:25:40 AM
If the piston won't respond to the suggestions above it's time for a rebuild anyway as the handbrake won't be responsive.
Post by: smithymc on July 09, 2012, 09:49:49 AM
Thanks all.  After some rummaging I found an old trim pry-bar with a square shank that worked a treat - once they started to move it was easy. It was even pretty good for prying the caliper to get the wedges in.
In doing the job, I found some quite corroded brake pipes up around the fuel tank ( and some more nasty fuel pipes). Are the braided brake kits a good choice and easier to work with than metal pipes in the confined space? Any thoughts?
Thanks.
Post by: Neil-yaj396 on July 10, 2012, 07:21:46 AM
The braided kits only replace the flexible (rubber) pipes. You will need a full pipe kit or to get the new sections you need made up.
