General Category => Members Cars => Topic started by: raz1966 on February 18, 2012, 10:33:44 PM
Title: just about given up....
Post by: raz1966 on February 18, 2012, 10:33:44 PM
i still cant get my car to run right, i double checked the cam timing and ignition time, stripped the carb (thats about 5 times now) but it still seems to running very rich, it ticks over rough but seems ok at about 3000 rpm, it wont go over 4000 rpm and if i floor it it back fires. i am certain all the jets are clear and fitted in the correct holes. its getting to the stage where i want to put the bloody thing on ebay.
Title: Re: just about given up....
Post by: MattNoVAT on February 19, 2012, 07:49:11 AM
I would recommend leaving it for a while and come back to it I a few days. Sometimes you get snow blind with the issue and it's better to have a break from thinking about same issue.
I would also check the condition of the gaskets between the carb, spacer and manifold. I had an issue with the old gaskets failing and it was allowing air to be sucked in at the base of the carb.
I assume the distributor has been set up and you have adjusted the timing from there?
Post by: cheeky monkey on February 19, 2012, 10:40:25 AM
Does it having a vacuum advance unit by the distributor.?
G
Post by: rossocorsa on February 19, 2012, 10:44:32 AM
have you removed the mixture screw in the base of the carb and blown that channel through as well as the jets? Still sounds like blockage in the carb to me or ignition issue but as Matt says I'd relax for a week and then get back to it. second thoughts any chance it has the fuel pump removed and an electric one fitted without a regulator that would probably flood it ?
Post by: raz1966 on February 19, 2012, 11:17:12 AM
there is a gasket at the base of the carb and a spacer, they look quite new, yes it has vacum advance, i am fairly sure the ignition timing is correct, mine is different to what it show in the haynes manual, i dont have marks on the yellow plastic cover, mine has marks on the pulley, one for tdc and one for firing.
Post by: raz1966 on February 19, 2012, 11:18:45 AM
it has mechnical fuel pump, and it is returning fuel back to the tank.
Post by: rossocorsa on February 19, 2012, 12:30:14 PM
just thinking if the sump was full of fuel when you got the car is it possible that there is a problem with the fuel pump (faulty diaphragm etc) causing fuel to get into the sump and poor/erratic fuel supply?
Post by: raz1966 on February 19, 2012, 01:57:44 PM
the fuel in the sump was caused by the accelerator pump diaphragm, i think the fuel pump is ok
Post by: WestonE on February 19, 2012, 02:28:35 PM
OK Deep breath and try not to kick anything that matters. Take the checks a step at a time:
With clean dry plugs (new for preference or bake in oven to dry them) check you get a fat blue spark with 1 plug earthed to cylinder head making sure you use insulated tools or gloves.
Look through ALL connections on the ignition including the HT lead connectors for loose burnt or corroded. Also for rotor or cap cracking or burning.
Check the timing use TDC with an adjustable strobe light and check your TDC marker really is at TDC by rocking the engine with a screwdriver rising and falling from number 1 piston TDC is in the middle of the dead zone.
disconnect the vacuum advance and plug the manifold end temporarily. Test the cars running with it disconnected.
with the car running spray WD40 around the manifold to head and carb to manifold join. If the running suddenly changes you have an air leak to fix
Remove the fuel to carb hose and spin the engine with the fuel hose in a large jam jar. Do you get plenty of clean fuel? Has it got bits of rubber in it from the hoses breaking down? This is very common with old fuel hose along with a huge risk of it just snapping causing fire. The Haynes manual might give you litres per hour for the pump in which case simple maths for Millilitres / minute checked with a kitchen measuring jug.
If the fuel delivery is poor change the in line filter first and check if there is a filter between the tank outlet and the pump. Is it blocked? Remove the sender and look into the tank is it full of rust and scale?
With this done I would do a compression test and borrow a carb that is known to be working WITHOUT touching and screws or jets and using new fuel hose with a filter in line between the fuel pump and carb inlet. If this makes no difference test the coil/ amplifier against their published resistance figures using a multi-meter.
I know it looks like a lot but do it slowly and carefully and you eliminate the other possible causes before facing up to potentially sending the carb off to be professionally refurbished.
We have all been there. Good Luck
Post by: raz1966 on February 19, 2012, 04:42:14 PM
i have tried to kick the dog but its too fast for me...
i took the carb off and made sure all the carb to manifold gaskets are sealing ok.
the plugs are new, the leads are new, the dizzy has just been refurbished and there is a nice spark t the plugs,the fuel lines are new and there is plenty of fuel coming through.
it starts but runs lumpy and occasionly back fires through the carb,if i turn the engine off i can see fuel actualy filling up the front venturi, it also seems to be spitting back unused fuel out of the top of the carb.
i have fitted new needle valve and valve seat. i tried it with the old ones in, still the same.
i have tried a couple of floats but no change, i am not sure how to set the float hight.
on the plus side i can now take the carb of a lancia twin cam in about 3 minutes.
Post by: raz1966 on February 19, 2012, 04:49:42 PM
it has used about £10 of petrol in abouts 10 minutes!!!
Post by: rachaeljf on February 19, 2012, 05:56:44 PM
Sounds like you have an internally damaged carb or failed needle valve. Have you fitted an electric pump?
Post by: raz1966 on February 19, 2012, 06:18:48 PM
it has a mechaical pump, i want to keep it original, needle valve is new, i have tried  different carbs...same problem with both carbs
Post by: peteracs on February 19, 2012, 07:37:45 PM
All sounds very frustrating, but given all this spitting have you checked the cam timing as even if the rest is spot on, then maybe that is out and causing chaos with the compression, but not out enough to cause it not to run?
Post by: raz1966 on February 19, 2012, 07:54:18 PM
checked the cam timing and its is spot on
Post by: WestonE on February 19, 2012, 07:54:51 PM
Raz
Buy a fuel pressure regulator set it to 3PSI with an in line gauge and try again. if that pump if too strong it will be blowing the needle valve off its seat and causing gross flooding. If you buy a filter king with a built in regulator and gauge you have what you would need to regulate an electric Facet Silver Top Competition pump which is what you would use with twin carbs and they work fine with the original carb with a regulator.
Also is the return line blocked or restricted anywhere because this would have a similar effect? NB with electric pumps you do not use a return because they turn themselves on and off as needed.
I would definitely do a compression test to know the core engine is sound and this will tell you if the cams are grossly miss-timed.
I pity the dog
Post by: HFStuart on February 19, 2012, 08:20:31 PM
I was just thinking that very thing (ie cam timing). Certainly worth checking - but ideally without reference to any of the pointers just in case they're misleading in some way.
This bit intrigues me though 'if I turn the engine off I can see fuel actually filling up the front venturi'. With the engine off and a mechanical pump there should be no pressure in the system where's this fuel coming from? If the float level is really out the fuel chamber can overflow. With the design of the carbs it's quite possible to bend the floats when taking the lid off.
To adjust the float level you just bend the tang that pushes up on the needle valve. Bend it up to lower the level, bend it down to raise it. Haynes doesn't give a level for it and the workshop manual gives a bizarrely complex method of testing (pm me with your e-mail and I'll send you the pages) but as a guide hold the top of the carb vertically with the floats hanging down so the needle valve is just closed. The top of the float should be parallel to the carb flange and typically (not always) 7mm away from the gasket on a DMTR
Post by: raz1966 on February 19, 2012, 08:30:03 PM
i will check the return fuel line as i have not thought of that.
i know it is coming out of the return of the carb as it comes out if you leave the pipe off.
on tick over i can actually see fuel blowing back through the carb.
Post by: raz1966 on February 19, 2012, 08:33:57 PM
i will check the float level tomorrow stuart, i have got spare floats but the same thing happens when i change the float to a spare one, i guess they could both be bent.
Post by: raz1966 on February 19, 2012, 08:37:26 PM
what should  the compression be? 170 psi?
Post by: raz1966 on February 19, 2012, 09:34:18 PM
the more i think about it i think it might be the return to the tank blocked, i will check that after work tomorrow
Post by: rachaeljf on February 19, 2012, 10:34:11 PM
Sorry I missed that you had a mechanical pump. I guess it's possible that with the return line blocked the pump is pressurising and "pumping up" the fuel hose to the carb, so that even when stopped the residual pressure is forcing fuel into the chokes. Otherwise fuel cannot simply fill up the chokes with the engine not running.
Post by: thecolonel on February 19, 2012, 11:20:24 PM
Could also be pressurized fuel tank causing
Fuel to be pushed back down the return line.
Post by: betaveloce on February 20, 2012, 03:49:51 PM
I had exactly this problem with my Spider
check how the car works with the fuel filler cap removed!
Post by: raz1966 on February 21, 2012, 02:12:48 PM
compression is 175 psi on each cylinder which  think is ok, i have cleared the return line and it seems to be running a bit better, it seems to rumble a bit as you rev it , is that mains or big ends? it has good oil pressure . should i worry?
it still running rich but i have ordered a colourtune kit and i am going to double check the ignition timing.
Post by: WestonE on February 21, 2012, 03:16:22 PM
The compression number is fine particularly if it is even across the cylinders i.e. not more than 10% variance. Low rumble is unfortunately likely to be main bearings. Use a long handled screwdriver one end on sump one end to ear to listen to check. You might just be able to change the shells and get away with it. All that fuel in the oil will be the cause.
Post by: thecolonel on February 21, 2012, 04:00:34 PM
Hope you chucked all the fuel contaminated oil away
and replaced filter etc.
If not do it straight away.
Post by: raz1966 on February 21, 2012, 08:23:04 PM
its got new oil and filter, can i do the shells with the engine still in?
Post by: HFStuart on February 21, 2012, 10:35:53 PM
Not the mains no, big ends yes.
Post by: raz1966 on February 21, 2012, 10:50:11 PM
which is it more likely to be? i may leave it and rebuilt the engine in a year or so
Post by: HFStuart on February 21, 2012, 11:13:19 PM
Low rumble is probably mains, knocking under load or at 2-3000rpm would be big ends.
The mains will most likely go on for some time. So long as you have decent oil pressure and the rumbling isn't too bad they will probably be OK to leave for a while.
Post by: raz1966 on February 22, 2012, 05:58:57 PM
i think its the big ends.
its still running rough, what ever i do it seems to be running rich, sometimes it will run ok and all of a sudden it will back fire  and the run rough again.
Post by: raz1966 on February 22, 2012, 08:05:13 PM
if i look down the carb wih the air filter off i can see droplets of petrol coming out of the small pipe that connects to the accelerator pump, it only comes out as i blip the throttle, i know the accelerator pump puts fuel in to the engine as you floor it but how much should come out? i have got it to run up to the red line now and it seems to run better at high revs when it is on the second choke. also roughly how many turns out  should the screw near the manifold be?
Post by: Neil-yaj396 on February 23, 2012, 07:59:49 PM
Rumbling can be the water pump bearings rather than the engine bearings. The Beta's bodyshell tends to transmit all sorts of strange sounds!
Post by: wheelies on February 26, 2012, 05:42:21 PM
Hi Raz
Have you had the distributor out of the casing?
If so is it out 180 degrees?
You can get the engine to run but it will sound like a bag of hammers. You end up retarding the ignition so far thet it will try and fire on another cylinder.
I would suggest you go back to Erics suggestion and follow the timing through from scratch.
Set timing marks to TDC
Remove spark plugs and find the piston nearesst TDC, using a srewdriver rest the end on top of the piston you think is the highest.  Move the piston ever so carefully by putting a spanner on the timing pulley. Don't get the screwdriver jammed between the top of the piston and head. Move the piston backwards and forwards until you are satisfied it's at TDC.
Take cam cover off to ensure you are timing on the right piston, both valves should be closed as you near tdc, then the exhaust valve will start to open.
Check which terminal the rotar arm is pointing at in the distributor, it should be the one you have at TDC
Once you have the engine running, fine tune it with a strobe.
Good luck
Think of it as a game or a crossword, leave it and go back to it another night. You will win in the end.
Post by: raz1966 on February 26, 2012, 08:01:16 PM
its timed correctly, i have checked and re-checked
Post by: raz1966 on February 26, 2012, 08:07:15 PM
it runs ok above 3000rpm, below that it is rough and occasionally back fires
Post by: andybeta on February 26, 2012, 11:43:34 PM
Hi,
I am new to this thread. Others have been suggesting good back to basics fault finding advice.
First is this an engine you don't know it's provenance? Has it previously run well? If you have serviced something you might have unknowingly changed it eg timing or if you have changed the cam belt - one tooth out. If you can say 100% that all the basics are as they should be then I would think about the engine experiencing over fueling which as you describe will tend to happen at low revs. The carb can only take max 3.5 psi of fuel otherwise it will flood due to over fueling. At higher revs it might be able to handle the extra fuel as the second carb opens but unlikely at low revs. You do say the engine is running very rich and back firing plus you can see the float chamber filling. As previously suggested, by EW I think, fit an in-line Fuel King pressure regulator you can then control the fuel pressure to the carb very easily. You might as well replace the fuel lines if they are perished in any way and fit a new fuel filter.
The other thing which can cause back firing is a very blocked sump breather hose.
Have you pointed your finger at the distributor low tension circuit pick up yet as this is can fail causing really really rough running, the engine won't rev above about 3-3.5k rpm? Failed on mine. Was replaced. Problem solved.
HTH.
Post by: raz1966 on February 27, 2012, 06:31:17 PM
engine is low milage (60000) but has not run for 10 years, dizzy is new, i have not unblocked the breather, how do i do it?
i dont want to fit anything to the car that is not original
Post by: raz1966 on February 27, 2012, 08:03:51 PM
i am still unsure about setting the ignition timing, i know what mark to use but in the instructions i have (translated from italian) it says strobe it at 3000 rpm. i have been told to do it 1000 rpm , does it make ant difference? i am checking it with the vaccum pipe disconnected. any one know the correct way?
Post by: rossocorsa on February 27, 2012, 09:03:31 PM
28 degrees at 3000 rpm vacuum advance disconnected
Post by: HFStuart on February 27, 2012, 11:27:06 PM
Or indeed the 10 degrees at 1000rpm I'd already suggested....
Post by: raz1966 on February 28, 2012, 08:17:42 PM
i think the mark on my crankshaft pulley is at 28 degrees, i misread you message stuart....my fault
