Technical stuff => Suspension => Topic started by: rossocorsa on June 20, 2020, 11:17:03 PM
Title: Reassemble strut/coil assembly
Post by: rossocorsa on June 20, 2020, 11:17:03 PM
I actually found 4 original NOS rubber rings for the front struts which was great, now I'm going to reassemble the front struts soon and I'm just thinking do I fit these dry or does it make sense to help longevity with silicone spray or silicone grease? Anyone got any ideas?
Title: Re: Reassemble strut/coil assembly
Post by: megaera on June 20, 2020, 11:37:00 PM
https://www.classicoils.co.uk/red-rubber-grease (https://www.classicoils.co.uk/red-rubber-grease)
Post by: WestonE on June 21, 2020, 10:58:33 AM
I would fit them dry or with dry PTFE spray because grease in this area will collect dirt and grit grinding the collars and springs away over time.
Post by: rossocorsa on June 21, 2020, 11:24:45 AM
that is what I was thinking really, I checked the official workshop manual and it indicates (by omission of any instruction) dry assembly, I think this is correct in that the spring isn't intended to slip on the mounting. I just thinking really about protecting the rubber from perishing I might put a light coating of ptfe spray just on the edges after assembly.
