April 24, 2024, 12:59:40 AM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
: Looking for Lancia Beta parts:
www.lanciabetaparts.co.uk
Home
Help
Contact Admin
Search
Calendar
Gallery
Articles
Login
Register
Technical stuff
Wheels/Tyres
Wheel.......bearings
Pages:
1
2
« previous
next »
Author
Topic: Wheel.......bearings (Read 16351 times)
Offline
United Kingdom
Re: Wheel.......bearings
Reply #20 on:
January 09, 2011, 03:16:28 PM »
Get the tool from Mark but first tap out the indent lock on the ring then use an impact gun to shift the ring. To put old bearing out and in try to borrow a press as hitting bearings will have you doing it again!
Offline
United Kingdom
Reply #21 on:
September 02, 2018, 10:57:30 PM »
Major thread revival alert...
I've recently been engaged in trying to get the set of uprights/hubs/bearings I acquired from Peter (peteracs) broken down into their constituent parts, so I can refurbish the uprights and use them for my (current) cunning plan. After reading Mark Wastnidge's account of how he made up a 'special tool' to remove the bearing retaining ring, I followed his lead and bought an M30 bolt (with 46mm head), cut off the shank and ground the underside of the bolt head flat. I then acquired some 12 x 8mm bar and cut one long length (63 mm) and 4 short lengths (23 mm). The indents in the retaining ring are 8mm wide. I then tack-welded the 63mm length in place on the underside of the bolt head and (having seen the rubbish quality of my welds) took the rest along to a professional welder to finish off.
All the pieces were positioned in the retaining ring (still fitted to the hub/upright assembly), with the bolt head sitting on top and the welder then welded the other 4 legs in place from on top. He then flipped the 'tool' upside down and welded all the pieces to each other and the underside of the bolt head. I haven't taken any photos, but will do if anyone is interested.
Even after giving the retaining ring some serious heat, followed by a soaking in Plus-gas, and attacking the retaining ring with my new tool and a mains-powered electric impact gun, the retaining ring only unscrewed painfully slowly. It took ages hammering away with the impact gun until it eventually gave best and unscrewed. Why are these things in so tight? Is it lack of lubrication when fitting, corrosion or work-hardening in use? I stress I was doing all this at a workbench with a hefty vice, good lighting and a full array of tools. Doing it in situ must be a nightmare...
smithymc
Offline
Reply #22 on:
September 07, 2018, 07:28:14 AM »
I seem to recall that I measured the tool I borrowed from Peter, with the intent of producing a drawing.
I will dig about and see how far I got.
Offline
United Kingdom
Reply #23 on:
December 03, 2018, 12:04:21 AM »
At some point in the not too distant future I will be fitting new wheel bearings to the uprights I've overhauled, with new retaining rings supplied by Betaboyz. In theory it should be possible to re-use these retaining rings, but corrosion and over-zealous staking seems to take sufficient toll on them that most people replace them each time.
Has anyone tried using Loctite to secure these rings rather than staking them? I wouldn't use the high strength green stuff, but medium strength blue Loctite should stop any possibility of the rings unscrewing by themselves. Loctite also acts as a corrosion barrier, which should be useful.
Interested to know if anyone has tried this approach.
Offline
United Kingdom
Reply #24 on:
December 06, 2018, 11:30:22 PM »
Due to the deafening silence, I'll take that as a 'no', then...
Offline
United Kingdom
Reply #25 on:
December 07, 2018, 11:50:27 AM »
Hi Graham
I have always staked them, but just enough to locate them given how tight they are fitted.
Offline
United Kingdom
Reply #26 on:
December 07, 2018, 02:53:23 PM »
Hi Eric,
Yes, that would be the other option. The only ones I've ever had to remove were in unbelievably tight. Took about 20 minutes with the proper tool and an impact gun to free them off, so I concluded that staking them was definitely belt and braces.
Pages:
1
2
« previous
next »
Please select a destination:
WELCOME TO THE LANCIA BETA FORUM - READ THIS FIRST
=> Welcome Message
=> Forum Rules, FAQs and basic user guides
=> Feedback and recomendations for the forum
General Category
=> New members
=> Members Cars
=> Back in the day
=> General Discussion
=> Group Buys
=> Off Topic
=> Betas in the Press
=> Events 2024
Technical stuff
=> Part Number Requests
=> Engine
=> Transmission
=> Fuel System Carb
=> Fuel System Injection
=> Fuel System VX
=> Heating/Cooling
=> Exhaust System
=> Ignition
=> Brakes
=> Electrical
=> Suspension
=> Steering
=> Wheels/Tyres
=> Interior
=> Manuals / Spec sheets
=> Body
=> Tuning and competition
Keeping your Beta on the road
=> Specialist Lancia Garages
=> Lancia Friendly Companies
=> Owners Useful Tips
Classifieds: Cars/Parts for sale/wanted
=> Collectables and Memorabelia
Reproduced Parts Information
=> What parts would you like reproduced?
Previous years Events
=> Events 2023
=> Events 2022
=> Events 2021
=> Events 2020
=> Events 2019
=> Events 2018
=> Events 2017
=> Events 2016
=> Events 2015
=> Events 2014
=> Events 2013
=> Events 2012
=> Events 2011
=> Events 2010
Archive from MSN Forum 2002 - 2008
=> Events 2008
=> Archive from MSN Forum 2008
=> Archive from MSN Forum 2007
=> Archive from MSN Forum 2006
=> Archive from MSN Forum 2005
=> Archive from MSN Forum 2004
=> Archive from MSN Forum 2002 - 2003
Loading...
