July 24, 2024, 04:15:05 AM *
Author Topic: Changing heater radiator Beta spider 2000 1979  (Read 360 times)
spider1979
Newbie
Netherlands Netherlands
« on: May 16, 2024, 11:11:01 AM »
As the radiator of the heater is leaking seriously, I intent to change it together with the regulating valve, all hoses are already disconnected I have a replacement for radiator as wel as regulating valve.
Now is my question is there anybody on this forum  who has done this job before and can give me information on the sequence of dismantling and removing of the old radiator.
Thanks beforehand
Spider 1979.
« Reply #1 on: May 16, 2024, 11:34:01 AM »
It's described in the Haynes manual on pages 270 onwards. But basically, remove the centre console, undo a couple of the control cables and the hoses you can get to. The bottom half of the assembly holding the heater matrix is held in place by 2 spring clips either side and should drop out when these are released. You ought to be able to remove the assembly and replace it fairly easily.
Fiat Panda 100HP and now!
spider1979
Newbie
« Reply #2 on: May 20, 2024, 09:51:33 AM »
Thanks Guy, I was a bit worried as the situation in Haynes book is not exactly as in the latest versions of the 2.0 ltr Spider, v.i. ther are 6 clips holding the bottom casing, two of wich are stucked away against the engine bay bulkhead, you need baby hands and super power to release them. In the meantime thr element is changed and the bottom part refitted. Thanks again for your instructions.
greeting Jan.(spider1979)
