April 19, 2024, 02:20:47 PM *
Author Topic: WOSP starter motor  (Read 2830 times)
Alt.Clr
Italy Italy
« on: November 22, 2021, 11:15:59 AM »
I'm looking for an uprated and lighter starting motor for my Beta Coupè restoration. Searching around I found a good number of WOSP model but it is difficult to understand which is the right model for the Beta (also because WOSP site looks like is not online anymore).
Do you guys have any experience with this starteres? Do you know which is the correct one (serial number)?
Many thanks
« Reply #1 on: November 22, 2021, 11:37:57 PM »
Hi,
I recently purchased and fitted a LMS061 from AE Supplies to my 2000 HPE.
It cost 241.26.
Hope this helps.
Alt.Clr
Italy Italy
« Reply #2 on: November 23, 2021, 10:55:28 AM »
Many thanks @Nigel, that's exactly the info I was looking for.
Was it a straight fit or some modification were needed?
« Last Edit: November 23, 2021, 11:50:07 AM by Alt.Clr » Logged
« Reply #3 on: November 23, 2021, 11:03:32 PM »
Alberto,
No mods needed at all. Bolts right in, very easy.
The one improvement that is very worth while is to fit
a relay. This takes the solenoid load off the ignition switch [which is not strong
at the best of times].
Regards,
JohnFol
« Reply #4 on: November 24, 2021, 07:10:30 PM »
Last time I worked on the starter I had the battery tray out and the carb removed. I now have a WOSP waiting to be fitted. Can I get away with just removing grill and radiator and working from the front of the car?
« Reply #5 on: November 24, 2021, 08:45:33 PM »
Alberto,
Regards,
Pardon my ignorance Nigel, but what cables go to what terminal numbers on the relay?
« Reply #6 on: November 24, 2021, 10:17:11 PM »
Evening Gents
John, I am fortunate to have the later fitment where the rad is mounted quite far forward so
I could fit it without removing anything significant. I know it's a squeeze on the early cars,
probably, as you say, rad out, or maybe just the fan housing? I worked from only the top.
Stuart, using a 5 pin relay, pins 85 and 86 are the windings, so one of those to earth, and
the other is Red from Ignition[which would have gone to the starter solenoid].
Then 30 is common, so that needs a battery 12v.
And finally,87 [normally open] goes to the new WOSP solenoid.
I haven't actually fitted my relay yet, and I plan to use the spare factory relay/fuse box mounted
on the left side wheel arch as it already has relay space,12v and earth nearby.
Hope this helps, Nigel
« Reply #7 on: November 24, 2021, 10:50:06 PM »
Hi Nigel,
Are you sure it's a 5 pin relay? You've only mentioned four pins (30, 85, 86, 87)
« Reply #8 on: November 24, 2021, 11:28:46 PM »
Graham,
 Pin 87a is the unused normally closed.
« Reply #9 on: November 25, 2021, 01:22:43 AM »
Graham,
Hi Nigel,
Ok, thanks. Please humour me as I'm clueless about electrics, but could you just use a 4 pin relay, or does the unused pin in a 5 pin relay still have a function?
« Reply #10 on: November 25, 2021, 08:36:59 AM »
What is described is a normal 30am switching relay that can be 4 or 5 pin. 87 and 87a are twin outlets on the 5 pin version. Just make sure you do not try to use a change over relay which typically get used to help electric windows. These have a different diagram on the top.
Remember these things are just remote switches with a helpful diagram on top.
« Reply #11 on: November 25, 2021, 05:24:02 PM »
Thanks Eric, that explains it well. I guess the 5 pin relay is used when needing to actuate/control more than one output from a single input?
« Reply #12 on: November 25, 2021, 06:27:40 PM »
Graham,
I should have posted this last night. Should clarify the workings.
« Reply #13 on: November 25, 2021, 06:48:08 PM »
That is a change over relay Nigel. i.e. it switches the connection between 87 and 87a. Typically You want the one that shows 87 and 87a joined together as dual outlets switched on when the coil is energized.
I have no images available to share right now.
« Reply #14 on: November 25, 2021, 10:24:17 PM »
That got me out to the garage Eric. Upon energising 85 and 86, contact is made between 30 and 87, and is lost between 30 and 87a.
When I de-energise 85 and 86, contact is lost between 30 and 87 and made at 30 and 87a.
The diagram may not accurately reflect this, but the relay is good for this purpose.
« Reply #15 on: November 26, 2021, 09:42:27 AM »
Hi Nigel
Sorry for the stress. You test means you know for sure on 87 vs 87a for your needs. As I said the more common type you can connect to 87, 87a or 87 & 87a and they all provide switched power.
« Reply #16 on: November 26, 2021, 10:39:18 PM »
Hi Eric
I am curious why you need a relay with two pins connected to the same point?
Also I would have assumed the naming convention for these devices is consistent with 87a always being normal connected?
« Reply #17 on: November 27, 2021, 09:44:08 AM »
Hi Peter
Energizing 2 circuits at the same time on a split in the loom. There is a Relay convention document and I have it somewhere for aiding restful sleep. 87 normally is the priority switched output.
