April 16, 2024, 10:38:07 AM *
Author Topic: Starting problem  (Read 1266 times)
JohnFol
« on: August 28, 2021, 07:11:42 PM »
Morning all, 1 frustrating,  intermittent problem that has been there since I got the car.
About 1:3 the starter doesn't turn the engine but suddenly it spins and fires. I highly suspect the starter however...
Starter refurbished
Alternator refurbished
New battery
New cables to starter, alternator, fuse box and earth leads
New coil (question mark over to-balast or not to-balast)
New ignition switch
Ignition feeds relay that goes to starter solenoid
I tend to leave car on trickle charge so happy battery is not low (also happens if for example I restart after putting petrol in)
So, unless something engine / transmission is sticking its symptomatic of a starter.
I don't have time to get it retested any time soon and happy to pick up another at Beaulieu nest weekend.
Any thoughts, ideas of what else to check?
« Reply #1 on: August 28, 2021, 10:13:19 PM »
I would suspect solenoid or feed/ground to the starter
JohnFol
« Reply #2 on: August 28, 2021, 10:53:57 PM »
Thanks Peter. Both things I can test at home
« Reply #3 on: August 29, 2021, 08:40:28 AM »
Get rid of that OE Starter and use a WOSP reduction gear unit. The OE units are heavy and an ancient design with very few people able to properly re-build them.
the WOSP unit is a fit and forget solution so avoid another tired unit from Beaulieu
JohnFol
« Reply #4 on: August 29, 2021, 11:13:13 AM »
Eric did you fit the Wosp LMS061 to your spider as they only list Monte..?
« Reply #5 on: August 29, 2021, 11:56:31 AM »
Hi John
Yes
