March 08, 2021, 02:34:13 PM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
: Looking for Lancia Beta Parts
Lots of new items recently added
see:
www.lanciabetaparts.co.uk
Home
Help
Contact Admin
Search
Calendar
Gallery
Articles
Login
Register
General Category
Members Cars
Replacement Engine project
Pages:
1
2
« previous
next »
Author
Topic: Replacement Engine project (Read 540 times)
Online
United Kingdom
Re: Replacement Engine project
Reply #20 on:
February 21, 2021, 10:24:32 AM »
Hi Graham
Curious what was used on your engine?
Saab 9-3 1.9Tid Cabrio
Offline
United Kingdom
Reply #21 on:
February 21, 2021, 10:28:40 AM »
Hi Peter
I forget sometimes that other people have not had the misery of being trained in lubricant technology. By Zinc you mean ZDDP which is an agent that promotes oil film retention and metal to metal pre-lubrication. It has been reduced in some modern oils because it is hostile to catalytic convertors. It's advantage is at cold start and first start. But too much in a freshly built engine and you can face serious bedding in issues particularly the rings which need to wear into the bores to create a seal. This is why you start with good quality running in oil not the finest Synthetic you will switch to after running in.
If pre-lubes dry out from storage you get problems with blocked drillings and oil starvation issues. New cams MUST be given start up lube just before start up to protect the case hardening and they need to run at 2000 RPM for 5 to 10 minutes to bed in. With used cams I have used moly grease coating at first start up with no issues. I like the Kent Cam lube for new cams. It has all you need and is easy to get.
Some engines have designed in lubrication challenges so may need more start up lubricants. If you go this way the engines needs a regular turn over and warm dry storage just like with engine oil. But you also want to be doing a swap to fresh running in oil and new filter soon after the first run up to temperature holding 2000 RPM.
Ultimately you make your own scary decisions.
Offline
United Kingdom
Reply #22 on:
February 21, 2021, 10:37:55 AM »
Thanks Eric,
I wasn’t aware the ZDDP content was being reduced in oils to save cat converters. I’ve always liked that feature of modern lubricants.
Beta Saloon 2000 s2 1979 (completed July 2020)
Aprilia RSVR 2002
Aprilia Tuono R (130 rear wheel BHP)
Alfa 159 sportwagon jtd eco (slower than a courgette)
Offline
United Kingdom
Reply #23 on:
February 21, 2021, 01:15:39 PM »
Quote from: peteracs on February 21, 2021, 10:24:32 AM
Hi Graham
Hi Peter,
I have to confess I am completely unaware of what was used on my engine build, but I'll ring Stanwood next week and find out what they use for engine reassembly lube.
Last Edit: February 22, 2021, 11:35:14 AM by mangocrazy
Offline
United Kingdom
Reply #24 on:
February 22, 2021, 11:37:48 AM »
Hi Peter,
Just rang Stanwood and they tell me that they use Lubriplate 105 as an assembly grease. Here's a link:
https://www.lubriplate.com/Products/Grease/Multi-Purpose-Greases/100-Series/NO-105/
They stock it and will be happy to sell you a tube. Guy was always effusive in his admiration for Stanwood, and I have found them beyond reproach in all my dealings with them.
Cheers,
Online
United Kingdom
Reply #25 on:
February 22, 2021, 12:13:27 PM »
Hi Graham
Many thanks for info
Online
United Kingdom
Reply #26 on:
February 28, 2021, 03:23:25 PM »
I mentioned before, but here are some photos of tools purchased to help out with the engine.
First up is a set of Moore and Wright micrometers. These are used good condition ones, imperial, but happy to do the maths when needed. I did not fancy a set of the cheap Chinese ones as it appears they can be hit/miss on quality.
Next is a Chinese bore gauge. I really wanted this just to gauge how round the bores are and asses the best block and the need for rebore on the blocks I have. The machine shop can do the real accurate stuff.
Lastly a magnetic stand and a finger type dial gauge (I have the rod type in the bore gauge). I bought this for the stand, but the dial gauge was only a little extra. Again my main reason for buying a cheap item was to give me an idea of variation, rather than anything which is super accurate.
Also on its way is a spring compression set, I already have the Fiat/Lancia tools for the shim replacement when that is needed.
Pages:
1
2
« previous
next »
Please select a destination:
WELCOME TO THE LANCIA BETA FORUM - READ THIS FIRST
=> Welcome Message
=> Forum Rules, FAQs and basic user guides
=> Feedback and recomendations for the forum
General Category
=> New members
=> Members Cars
=> Back in the day
=> General Discussion
=> Group Buys
=> Off Topic
=> Betas in the Press
=> Events 2021
=> Events 2022
Technical stuff
=> Part Number Requests
=> Engine
=> Transmission
=> Fuel System Carb
=> Fuel System Injection
=> Fuel System VX
=> Heating/Cooling
=> Exhaust System
=> Ignition
=> Brakes
=> Electrical
=> Suspension
=> Steering
=> Wheels/Tyres
=> Interior
=> Manuals / Spec sheets
=> Body
=> Tuning and competition
Keeping your Beta on the road
=> Specialist Lancia Garages
=> Lancia Friendly Companies
=> Owners Useful Tips
Classifieds: Cars/Parts for sale/wanted
=> Collectables and Memorabelia
Reproduced Parts Information
=> What parts would you like reproduced?
Previous years Events
=> Events 2020
=> Events 2019
=> Events 2018
=> Events 2017
=> Events 2016
=> Events 2015
=> Events 2014
=> Events 2013
=> Events 2012
=> Events 2011
=> Events 2010
Archive from MSN Forum 2002 - 2008
=> Events 2008
=> Archive from MSN Forum 2008
=> Archive from MSN Forum 2007
=> Archive from MSN Forum 2006
=> Archive from MSN Forum 2005
=> Archive from MSN Forum 2004
=> Archive from MSN Forum 2002 - 2003
Loading...
