April 19, 2024, 08:55:55 PM *
Author Topic: Replacement Battery / AH rating.  (Read 2700 times)
Sandro
Denmark Denmark
« on: May 16, 2020, 11:44:28 AM »
Hi all,
I wonder if you can help, I'm upgrading my Battery ( It's seen better days ) and besides getting the right fit size wise.
..whats the best AH rating to get ...they range between 44amp, 55, 70 and so on.
I have an ( unmodified ) 1984 2000 I.E. model.
Many thanks Andrew
1972 Honda cub
1984 Silver 2000i HPE
2005 Opel Vectra ( everyday )
« Reply #1 on: May 16, 2020, 01:51:17 PM »
The original taking was 45 Ah but you could probably go for something with more reserve
« Last Edit: May 16, 2020, 02:44:14 PM by rossocorsa » Logged
Sandro
Denmark Denmark
« Reply #2 on: May 16, 2020, 02:25:51 PM »
many thanks Rossocorsa. Smiley
A.
1972 Honda cub
« Reply #3 on: May 16, 2020, 05:43:58 PM »
Make sure it is not a leisure battery, ie get one suitable for starting the car. Although I have not direct knowledge, I believe they are constructed different. Ie a car one is designed for high current over short periods and the leisure are designed for lower current over extended periods for mobility scooters etc.
George-S
« Reply #4 on: May 16, 2020, 08:33:57 PM »
This discussion came up on the FB page not necessarily for an upgrade but this was what some people recommend as a replacement.
https://www.batterycharged.co.uk/shop/brands/duracell-automotive/duracell-advanced-battery-range/duracell-075-da60t-advanced-car-1241053.html?fbclid=IwAR1vMS4Wz8t6HKqHZsWBg3_Ra1JRXOX3DDbbFWJx6GQ-luVoI31GlXqVO-I
Cheers George
smithymc
« Reply #5 on: May 17, 2020, 08:49:27 AM »
I got one of these last year, a Varta C6 Silver Dynamic 52 Ah. Got it from Manbat in Shrewsbury. It really has some cranking power and fits the clamp perfectly- although I appreciate mine isn't an i.e.
betaveloce
Belgium Belgium
« Reply #6 on: May 17, 2020, 09:00:44 AM »
I have a Varta with the same characteristics as the Duracell (60 Ah and 540 A) in my HPE I.E.
The 45 Ah Rossocorsa is referring to, is for a carburated car I think.
The injection cars also have a heavier alternator than the carburated ones (65 Ah instead of 55 if I recall correctly).
Beta Coupé 1.8 '74
Beta Spider 1.6 '80
Beta HPE 2.0 i.e. '82
Delta Integrale 8V '88
Ypsilon 1.4 16V '09
Sandro
Denmark Denmark
« Reply #7 on: May 17, 2020, 10:45:58 AM »
Thanks everyone. that's useful (and timely) advice. I'm planning to replace the battery this week,
I'm having power 'drop-outs' and after initially thinking it was fuel supply related I think it's electrical so a fresh battery is a good start.
I'm going to take a look at the Alternator ...on one occasion the Alternator made a nasty noise ( for a period after the ignition was turned off )
maybe it was due to not getting enough power ?
Thanks again Andrew.
1972 Honda cub
« Reply #8 on: May 17, 2020, 11:33:45 AM »
The injection cars also have a heavier aiiii
I
The ie does have a bigger alternator but the l battery Ah was the same, I checked the tech book but as I said you can buy a bigger capacity of required.
« Reply #9 on: May 17, 2020, 03:00:49 PM »
How much was it Mark? I like Varta batteries and my current one has had a few too many recharges from winter lay ups I think.
betaveloce
Belgium Belgium
« Reply #10 on: May 17, 2020, 05:15:19 PM »
Oops, sorry, I wasn't aware that the batteries where the same despite the alternators being different...  Wink
« Last Edit: May 18, 2020, 07:51:14 AM by betaveloce » Logged
Beta Coupé 1.8 '74
Beta Spider 1.6 '80
Ypsilon 1.4 16V '09
Sandro
Denmark Denmark
« Reply #11 on: May 17, 2020, 09:24:23 PM »
Many thanks Mark I'll see if I can track one down.
Thanks Kevin, Neil, George Peter and Rossocorsa also.
A.
1972 Honda cub
smithymc
« Reply #12 on: May 18, 2020, 08:45:08 AM »
I think it was £60, which seems to be the going rate still online.
« Reply #13 on: May 18, 2020, 03:39:04 PM »
I will run with a 62 Amp Hour battery with my Bosch 65 Amp IE spec alternator, but I do have a supercharger and modern mapped FI to wire in. Have a critical look at your battery leads and consider some new custom red and black heavy gauge replacements. So many Beta items are a tatty corroded mess. A good battery earth and good battery starter/alternator connections fix many strange electrical issues. Replacements must be at least the same wire core size preferably thinner modern multi-core flexible items.
Clean up the earth connection points and add contact grease when you are done.
Sandro
Denmark Denmark
« Reply #14 on: May 18, 2020, 04:11:12 PM »
Thanks Eric,
I think that you're right, having a decent look at some of these connections today in the Garage,
they are indeed old and could do with looking at replacing and / or cleaning, I'm putting in fresh HT leads on, will check the distributor etc.
A friends Dad who once worked on betas here in Denmark also thinks that it's a poor connection somewhere ( as opposed to fuel supply ) given the way the power drops and comes back ..or not as the case may be.
I'll let you know what I find.
Many thanks Andrew.
1972 Honda cub
