March 29, 2024, 12:29:12 PM *
Author Topic: Beta HPE Front Caliper Refurb Help  (Read 4850 times)
Matt D
Newbie
« on: May 05, 2018, 09:27:05 PM »
Hello, I have made the hilarious mistake of thinking that Lancia Beta HPE front brakes are the same as every other car. After my dad and I managed to blow the piston out of the housing with a foot pump we realised very quickly that the piston would not clear the brake pad mounts. I have read a few things on this forum and elsewhere on the internet about there being some dowel pins which prevent the brake pad mounts from sliding away from the aluminium piston housing.
However, my caliper does not seem to have any of these dowels (see below images) and trying to seperate the two in a vice seems like a task I am not prepared to risk attempting without knowing exactly what im doing - a position I should have taken previously. I have attempted to drive a nail into the hole in the first photo however nothing freed off or even remotely moved, resulting in a blunt and bent nail. If anyone is aware of any guide, tips and tricks, or just a photo of where these dowl pins/retaining pins are located it would be of great help to me.
Thanks,
Matt
https://ibb.co/dzdkZS
https://ibb.co/jWbHg7
« Last Edit: May 05, 2018, 09:30:32 PM by Matt D » Logged
« Reply #1 on: May 06, 2018, 07:51:08 AM »
If I recall correctly the  pin is in the hole you can see on one side, the caliper is very fiddly to do. There is a second piston behind the first which is (again if I recall correctly) held in place by an internal spring clip. Have a look at the link below, hope it helps
https://photos.app.goo.gl/KFexqPv3YQNEFtGP7
« Reply #2 on: May 06, 2018, 08:42:05 AM »
I drilled out the pin and replaced with new one on assembly.
There are two pistons etc as per drawing.
The mount can take some patience to remove and will need some careful use of a hammer etc to slide it off the piston housing. It will come off eventually.
The other item which takes real patience is the retaing ring for the second piston from memory which I struggled with and needs great care not to scratch the bore.
All in all not a 5 minute job.
betabuoy
« Reply #3 on: May 06, 2018, 11:51:37 AM »
Matt
Finally, and I know it’s a bit defeatist, if you get really fed up with it Biggred did a splendid job on mine while I concentrated on some easier jobs. They weren’t that expensive either.
1967 Morris Minor Traveller
1925 Austin 7 Chummy
« Reply #4 on: May 06, 2018, 12:00:15 PM »
I think I recall that some items can be reached through the bleed screw hole, use of a small piece of copper sheet or similar as a shield will avoid scratching the bore. It is very very awkward though someone else with more experience (ex lancia dealer mechanic) ended up finishing mine
« Reply #5 on: May 07, 2018, 10:40:46 PM »
That sounds about right. The retaining ring is a bugger to get out and to avoid scratching the bore I use a bit of old rear plastic window from the Spyder. As you say there is a small hole which I used a thin round 'poker' to allow me to get a grip on the ring with some small pliers. Easy after the first time which took me ages to do, the second one was oh so much quicker. Remember to check that you have got all the bits out of the front calliper, check with the parts explosion as it was more complicated than I first thought.
fred2660
Belgium Belgium
« Reply #6 on: May 08, 2018, 07:20:24 PM »
Thanks,
Matt
look at these pictures
IMG_3811 by frederikleyers, on Flickr
IMG_3812 by frederikleyers, on Flickr
IMG_3813 by frederikleyers, on Flickr
after some time, even if this pin is not longer there, the piston holder and the iron pad case can be realy stuck together and you realy have to hit it to get it removed.
I cleaned the piston holder inside
IMG_3814 by frederikleyers, on Flickr
IMG_3815 by frederikleyers, on Flickr
this is the retaining ring we all talk about
IMG_3817 by frederikleyers, on Flickr
grts
