April 25, 2024, 05:52:33 PM *
Pages: 1 2 3 [4] 5 6 ... 9
Author Topic: beta coupe 1979 - 1600 from belgium  (Read 68448 times)
fred2660
Belgium Belgium
« Reply #60 on: October 30, 2017, 05:55:18 PM »
damn. I checked the oilpump clearance and not good.  Tha manual says max 0.15 mm between the gears. I can put 0.2mm between some gears.
IMG_3362 by frederikleyers, on Flickr
what do you think? have to change it?
also the manual says min lenght of the spring is 26.3 mm. Mine measures more like 25.8.
IMG_3363 by frederikleyers, on Flickr
(the photo gives a not so accurate image)
My pump has as part number 82317269
IMG_3365 by frederikleyers, on Flickr
the manual gives other partnumbers
IMG_3366 by frederikleyers, on Flickr
I also found some metal on several different locations in the oil channel. (some in the oil pump, others in the oil breather)
they are all the same
IMG_3358 by frederikleyers, on Flickr
IMG_3357 by frederikleyers, on Flickr
IMG_3354 by frederikleyers, on Flickr
any thoughts ?
« Reply #61 on: October 30, 2017, 10:10:03 PM »
Very odd. Fine turnings of some sort?
« Reply #62 on: October 30, 2017, 10:21:33 PM »
To me they look like a small spring clip that would go around a shaft but I can't think of anywhere that such a clip would be on a beta.
As regards clearances and spring spec. See the link below
https://photos.app.goo.gl/jDAyzLiwVkj3vuPD3
« Last Edit: October 30, 2017, 10:56:02 PM by rossocorsa » Logged
« Reply #63 on: October 30, 2017, 11:37:28 PM »
Remnants of a badly stripped thread?
« Reply #64 on: October 31, 2017, 09:59:33 AM »
Remnants of a failed helicoil?
fred2660
Belgium Belgium
« Reply #65 on: October 31, 2017, 11:21:48 AM »
I think they are copper. They are not magnetic, i checked.
lanciamad
Marcus Robinson
« Reply #66 on: October 31, 2017, 04:48:45 PM »
Could be the flame trap in the breather hose somehow disintegrated and found it's way around everywhere?
http://www.ricambio.co.uk/1601-breather-hose-flame-trap--classic-fiat-500-126-classic-panda-uno-cinquecento-punto-new-500
2001 - Honda Civic Type R EP3
fred2660
Belgium Belgium
« Reply #67 on: October 31, 2017, 06:51:26 PM »
yes, that must be it.
damn, then there are still a lot of metal pieces to be found. I checked both hoses connected to the breather, but nothing to be found there.
fred2660
Belgium Belgium
« Reply #68 on: November 03, 2017, 04:33:10 PM »
Okay, so I ordered a new flame trap (and some other things).
Not knowing what the function of the oil breather (or crankcase breather) is , i searched some on the internet. This video gives a good explanation of what it does and what the flame trap does.
https://www.youtube.com/watch?v=dkNand6EiFM
I took some pictures of the bottom of the oil breather. Is this complete or is there some part missing (besides the hoses and the bolt)
IMG_3372 by frederikleyers, on Flickr
IMG_3371 by frederikleyers, on Flickr
thqnks
capriblu
« Reply #69 on: November 03, 2017, 05:26:22 PM »
Have recently taken my unit off for general clean up and re-fit with new seal  (where it locates in port on block).  Looked just like your unit in photo.  Interestingly I didnt appreciate the function of strange gauze/wire in the exit hose - was a bit of a deformed mess but nothng loose, duly discarded.  I'll see if I can make something simple to substitute.
fred2660
Belgium Belgium
« Reply #70 on: November 12, 2017, 06:29:32 PM »
I am in dubio and like your advice.
I dont know the condition of the engine. I have had it started briefly but never drove it. Dont know the compression. Now I got the engine on an engine stand and i am thinking what should I do with it. Leave it like it is, or changing the head gasket or even disassemble the wole head , and why not do a total engine rebuild?
Is there any complete rebuild topic of the engine somewhere on the internet? I have looked but not found
I got the 828B000 engine bloc and 4314402 head
are there things I can check to see the condition of the engine (valves not closing, piston rings leaking,...?)
I have checked the sparkplugs and there is a lot of dry carbon on it.      but i think the wrong plugs were installed:  bpr6es instead of bpr7es
fred2660
Belgium Belgium
« Reply #71 on: November 13, 2017, 06:56:38 PM »
Bwaa, 'just do it', Nike used to say, so.... i took the head off.  The 10 headbolts all said 'tack', first i thought i was damaging them.
I am not a mechanic, (all my automotive knowledge comes from youtube, discovery channel, and if i am not to lazy the haynes manual) but at first sight i have tree remarks:
1) Like the spark plugs showed, the whole combustion rooms are all carbonised
IMG_3379 by frederikleyers, on Flickr
IMG_3380 by frederikleyers, on Flickr
IMG_3381 by frederikleyers, on Flickr
IMG_3382 by frederikleyers, on Flickr
IMG_3385 by frederikleyers, on Flickr
IMG_3416 by frederikleyers, on Flickr
IMG_3387 by frederikleyers, on Flickr
IMG_3388 by frederikleyers, on Flickr
IMG_3389 by frederikleyers, on Flickr
IMG_3391 by frederikleyers, on Flickr
IMG_3392 by frederikleyers, on Flickr
IMG_3393 by frederikleyers, on Flickr
IMG_3395 by frederikleyers, on Flickr
IMG_3398 by frederikleyers, on Flickr
IMG_3403 by frederikleyers, on Flickr
IMG_3405 by frederikleyers, on Flickr
2) the cilinders are quite smooth, no edges. but ons two cilinders there are some scratches
IMG_3406 by frederikleyers, on Flickr
IMG_3407 by frederikleyers, on Flickr
IMG_3413 by frederikleyers, on Flickr
IMG_3419 by frederikleyers, on Flickr
3) on one piston there is a little piece on the edge broken off
IMG_3414 by frederikleyers, on Flickr
IMG_3417 by frederikleyers, on Flickr
IMG_3418 by frederikleyers, on Flickr
IMG_3420 by frederikleyers, on Flickr
any thoughts?
« Reply #72 on: November 20, 2017, 06:41:33 PM »
Your engine has been running rich which is why you have black carbon not chocolate brown. Because of this expect worn bores from the excess fuel washing the oil away. You need to measure the bores using a bore gauge against the specification allowed, but I would expect you to need oversize pistons and a re-bore to get the best from the engine.
fred2660
Belgium Belgium
« Reply #73 on: March 12, 2018, 11:23:33 AM »
After  a long winter break I started working on the car again. On the rear end of the car there were some old repairs from a previous restauration. I decided to cut away these patches. Luckely because there was rust on the back side.
Old patches welded over the rust:
IMG_3604 by frederikleyers, on Flickr
IMG_3605 by frederikleyers, on Flickr
IMG_3606 by frederikleyers, on Flickr
my repairs so far
IMG_3594 by frederikleyers, on Flickr
IMG_3593 by frederikleyers, on Flickr
IMG_3595 by frederikleyers, on Flickr
IMG_3596 by frederikleyers, on Flickr
IMG_3597 by frederikleyers, on Flickr
IMG_3599 by frederikleyers, on Flickr
IMG_3601 by frederikleyers, on Flickr
IMG_3600 by frederikleyers, on Flickr
IMG_3602 by frederikleyers, on Flickr
IMG_3603 by frederikleyers, on Flickr
hope to start with filler soon now
grts
fred2660
Belgium Belgium
« Reply #74 on: April 24, 2018, 06:57:36 PM »
I did a rebuild of the carb (weber 34 datr, 1/250)
IMG_3640 by frederikleyers, on Flickr
IMG_3639 by frederikleyers, on Flickr
IMG_3634 by frederikleyers, on Flickr
IMG_3633 by frederikleyers, on Flickr
IMG_3632 by frederikleyers, on Flickr
rebuiild the front struts and put them on the car together with the subframe
IMG_3719 by frederikleyers, on Flickr
IMG_3720 by frederikleyers, on Flickr
IMG_3721 by frederikleyers, on Flickr
IMG_3718 by frederikleyers, on Flickr
IMG_3717 by frederikleyers, on Flickr
IMG_3716 by frederikleyers, on Flickr
IMG_3715 by frederikleyers, on Flickr
skidmarc
« Reply #75 on: April 24, 2018, 07:11:01 PM »
nice work hope you are enjoying your restoration.your car is going to look great when finished
betaveloce
Belgium Belgium
« Reply #76 on: April 25, 2018, 08:18:02 AM »
nice work Fred  Wink
Beta Coupé 1.8 '74
Beta Spider 1.6 '80
Beta HPE 2.0 i.e. '82
Delta Integrale 8V '88
Ypsilon 1.4 16V '09
George-S
« Reply #77 on: April 25, 2018, 08:59:47 PM »
Good work as always !
What welder are you using ?
George
fred2660
Belgium Belgium
« Reply #78 on: April 28, 2018, 04:54:07 PM »
George
thanks,
I use a mig welder
http://www.contimac.be/nl/product/41233219405358/mig-mag-contimac/basicline/ecomig-175
fred2660
Belgium Belgium
« Reply #79 on: April 28, 2018, 07:24:46 PM »
So I am rebuilding the front suspension. I installed the wishbones, new balljoints and the cv joints. I found a little hole in the boots off the outer cv joint, so I decided to replace them. I ordered hole new cv kits, inner and outer.
I removed the boots from the shaft, removed the inner cv joint but I can't get the drive shaft from the outer cv joint. Thats where I am stuck for the moment.
BTW: a lot of grease today
IMG_3723 by frederikleyers, on Flickr
IMG_3724 by frederikleyers, on Flickr
IMG_3726 by frederikleyers, on Flickr
the famous yellow mark again
IMG_3727 by frederikleyers, on Flickr
IMG_3728 by frederikleyers, on Flickr
IMG_3729 by frederikleyers, on Flickr
IMG_3730 by frederikleyers, on Flickr
IMG_3731 by frederikleyers, on Flickr
IMG_3739 by frederikleyers, on Flickr
IMG_3740 by frederikleyers, on Flickr
IMG_3734 by frederikleyers, on Flickr
I had this side already build before I found the hole i the boot
IMG_3736 by frederikleyers, on Flickr
IMG_3737 by frederikleyers, on Flickr
IMG_3738 by frederikleyers, on Flickr
