April 25, 2024, 04:55:10 PM *
Author Topic: Trying to find the correct alternator.  (Read 5944 times)
dougdee123
« on: April 14, 2016, 09:46:17 PM »
I started the coupe after a couple of months without use and the magic smoke escaped from the alternator. There is now 0V across the battery, warning light continuous and voltmeter doesn't get off the stop.
The dead one is a battered Magnetti Marelli 55A type.
I would like to replace it with a 65 A type but the only ones that are immediately available are also 55A types. I do recognise that Mark is selling race type alternators but they seem a bit steep at £205 and £210. Maybe if I can't find find an alternative.
Can anyone recommend a supplier? Or do I just have to keep looking?
All assistance gratefully received.
Doug
dougdee123
« Reply #1 on: April 14, 2016, 10:21:50 PM »
Aha!
This looks on the face of it as if it may be the answer. An alternator for a Delta integrale.
http://www.mister-auto.co.uk/en/alternator/cevam-4901_g4_a3934901.html
Would anybody care to offer an opinion on this? It looks like it has the same pulley size and the mountings look as if they should be similar.
Doug
PS I have another related question about the bush in the top adjuster link.
dougdee123
« Reply #2 on: April 24, 2016, 11:42:22 AM »
And the final answer is that this is a case of me being too clever for my own good.
When the alternator arrived it was indeed very similar but the bottom mounting had an extra, removable, steel spacer but the show stopper was that the plastic pulley was significantly further from the body of the alternator. The pulley fixings were also different to the original so I couldn't swap them over.
Hopefully I'll be able to return it for a less ambitious alternative.
Doug
« Reply #3 on: April 24, 2016, 06:31:28 PM »
Worth knowing - sorry you had to find out the hard way. Hopefully you'll find a suitable Beta one at the right price.
thecolonel
« Reply #4 on: May 09, 2016, 11:37:55 PM »
Pretty sure the astra mk 2 used
the same alternator.
ketmolnar
Newbie
Hungary Hungary
« Reply #5 on: August 07, 2019, 08:39:48 PM »
https://ketmolnarauto.hu/autoalkatresz-kereses?search=%0946231740
JohnFol
« Reply #6 on: June 27, 2020, 10:53:55 AM »
I know this is an old thread, but I have the 65A alternator and the Bosch part number is 0 120 489 142.
Reason I know? Battery has slightly higher voltage when engine turned off than when running so I suspect I have a charging issue
« Reply #7 on: June 27, 2020, 11:36:37 AM »
I have the exact same unit on my 1984 HPE, so this confirms originality at least.
« Reply #8 on: June 27, 2020, 08:48:14 PM »
Doug,
Have you considered replacing Just the regulator/brush assembly?
Often the bearings and windings outlast the regulator assembly and it’s cheap and easy enough to replace.
Just a thought.
JohnFol
« Reply #9 on: June 29, 2020, 09:15:39 AM »
This is something I've also considered. I found the list of parts that constitute the alternator https://www.woodauto.com/bom/33906/BOSCH-0120489142.  Would you also recommend swapping out the regulator as there soon becomes a break even point over a replacement unit.?
Ammy
« Reply #10 on: June 29, 2020, 09:57:27 AM »
Surprised to read all thse comments.  I just went along to my local autoelectrics dealer,  Edge in Tarporley, Cheshire , ordered one and picked it up next day ! ! !
smithymc
« Reply #11 on: June 29, 2020, 10:09:26 AM »
Same here, available to order- I've just been into the garage and taken a pic of the label.
JohnFol
« Reply #12 on: June 29, 2020, 11:22:10 AM »
This is what I got from a "live chat" with Bosch earlier. .
JohnFol
« Reply #13 on: June 29, 2020, 11:25:43 AM »
smithymc, I see that's a 55A. I was hoping to keep with the 65A but interesting reading as the part number gives me some more accurate measurements I can compare on web sites
JohnFol
« Reply #14 on: July 01, 2020, 10:17:15 PM »
Just had it reconditioned with new brushes, rectified etc. For £90 so a bit of a bargain. Also means 1 less item I  the diagnosis.
