Thankyou very much all for the replies, I was hoping that from some other unfortunate owner I'd receive a reply stating, "I have exactly the same problem! ", You guys with the regimes, are probably implementing the correct course of action in regards to a winter lay up ?. I too used to have one and I guess if I (remembered to) 'depressed' the clutch every week over the lay up period, i may indeed reduce the risk of the plate sticking?.
Neil-yaj396 its as dry as a the proverbial in the bell housing, no water or oil and as I overhauled the gearbox two years ago and inspected everything on rebuild so can confirm the plate and cover are in fine fettle.
Ammy, that's similar to the regime I used to have, but then one year when I'd forgot a 'warm up run' and let 3 months slip by, I thought "ah fkit, I'll sort it in new year!", came that year and I didn't use the car for a whole 12mnths !!!, the day the tax ran out, I pulled spark plugs, added a drip of clean engine oil to each bore turned over at crank pulley by hand and then left it until following year, that then became my regime, 'tax out, plugs out' and so on. Its just remembering and having the incentive and time to carry out these actions.
rossocorsa, used to do that too, run it through winter on nice dry days, then one day I got caught out by a 'nice dry salted winter day' that turned wet..... never again!, made a right pigs ear of the underside bare ally floor panels and powder coating
oh! and my garage floor!. As for the road tax saving, DON'T get me started!
I know what you mean about the first few drives after a lay up, noises,rattles, flats on all four tyres, scary brakes, gauges steaming up on the inside of the glass! and probably worse? the worrying smells
Come on someone, Get your car out of mothballs and have 'NO' gear selection at idle and use this excellent forum to post a query
Thanks again for all time and effort in replies so far.
Kev B.
