April 19, 2024, 12:32:38 AM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
: 2024 Events Calendar
http://www.betaboyz.myzen.co.uk/forum/index.php?board=92.0
Home
Help
Contact Admin
Search
Calendar
Gallery
Articles
Login
Register
Technical stuff
Heating/Cooling
Radiator Fan Thermostat
Pages:
1
2
« previous
next »
Author
Topic: Radiator Fan Thermostat (Read 29424 times)
Offline
Re: Radiator Fan Thermostat
Reply #20 on:
May 23, 2015, 02:21:22 PM »
Quote from: betabuoy on May 23, 2015, 12:29:39 PM
Neil
If still no joy - and you're confident the wiring is correct - I might have a spare in my garage at Cranwell. Just let me know if you need it.
As you say... fingers crossed!
Thanks Chris, did you get my PM about the trophy?
betabuoy
Offline
United Kingdom
Reply #21 on:
May 23, 2015, 05:44:35 PM »
Neil
Yes. Got your mail and I thought I'd replied. I'll check again.
1967 Morris Minor Traveller
1925 Austin 7 Chummy
Offline
Reply #22 on:
June 30, 2015, 09:19:37 PM »
Stuck in a traffic jam on the way home today in the blistering heat. Fan clicking on and off nicely, so hopefully this saga is at an end now.
What is alarming is when the fan comes on now (about half way on the temperature gauge), as compared to the old sensor (near the red, if it felt like it!).
Last Edit: June 30, 2015, 09:21:29 PM by Neil-yaj396
betabuoy
Offline
United Kingdom
Reply #23 on:
June 30, 2015, 11:10:42 PM »
Neil
Halfway is exactly how it should be but I do like the idea of Theo's mod whereby he's put a switch in the top hose and set it to a cooler level. I'm giving that mod some thought as I don't like the anxiety of seeing the needle even go so far as half way.
Offline
United Kingdom
Reply #24 on:
July 01, 2015, 12:16:06 AM »
I don't think it's desirable to run too cool, my preferred option has always been a manual override so if you are in a slow queue you always have the option to switch the fans on early.
Offline
Reply #25 on:
July 01, 2015, 06:28:02 AM »
Quote from: rossocorsa on July 01, 2015, 12:16:06 AM
Don't quite understand this one Alan. Not desirable to run cool, but switch the fans on early?
Offline
United Kingdom
Reply #26 on:
July 01, 2015, 08:30:54 AM »
Yeah my brain not functioning properly it was late! My reasoning for liking the manual override is that it allows some extra control without putting extra pressure on the fan all the time. If there is obviously a long slow queue a manual switch gives the option to engage the fan early on you own judgement, otherwise you can stick with the normal cycle.
Offline
Reply #27 on:
September 10, 2016, 11:39:12 AM »
After going through three thermostats in as many years (admittedly the first one had probably lasted 34 years) I decided to bite the bullet and fit this aftermarket unit.
The original Kenlowe version as fitted by Theo to his Trevi does not seem to be available any more. This one was inexpensive (£19.99) and I do have some concerns about it's durability, but it was easy to fit, seems to work well and has a very wide range of adjustment. I've set it to come on with the gauge at dead centre, which equates to 95 degrees on the dial.
I don't like fitting non OE parts, but it seems to me that the original units are possibly deteriorating with age? Fortunately, as reported before, the last two failed in the 'on' position.
capriblu
Offline
United Kingdom
Reply #28 on:
September 05, 2017, 09:18:30 PM »
Have been doing some work on my car which has necessitated removal of radiator so have decided to get thermoswitch functionality back. For several years have run on manual switch only running through separate relay but would feel happier knowing that there is a back up if I forget to look! Will still keep manual switch as optional override to bring fan on earlier if desired (i.e. as per Rossocorsa's suggestion). Given manual override option then would prefer to keep thermoswitch at original settings which from my recollection activates at a temperature corresponding to the temp gauge being just slightly over the half way mark.
Original part numbers Lancia/Fiat 82286103 Spec = M22 x 1.5 with nominal 92/87 degC on/off. Intermotor part 50200 is the matching item for this. The 50100 item has nominal on/off settings about 10 degC lower which is quite a long way off standard.
Searching online for the original Lancia / Fiat part number finds countless good brand new items matching the above for little £....
Pages:
1
2
« previous
next »
Please select a destination:
WELCOME TO THE LANCIA BETA FORUM - READ THIS FIRST
=> Welcome Message
=> Forum Rules, FAQs and basic user guides
=> Feedback and recomendations for the forum
General Category
=> New members
=> Members Cars
=> Back in the day
=> General Discussion
=> Group Buys
=> Off Topic
=> Betas in the Press
=> Events 2024
Technical stuff
=> Part Number Requests
=> Engine
=> Transmission
=> Fuel System Carb
=> Fuel System Injection
=> Fuel System VX
=> Heating/Cooling
=> Exhaust System
=> Ignition
=> Brakes
=> Electrical
=> Suspension
=> Steering
=> Wheels/Tyres
=> Interior
=> Manuals / Spec sheets
=> Body
=> Tuning and competition
Keeping your Beta on the road
=> Specialist Lancia Garages
=> Lancia Friendly Companies
=> Owners Useful Tips
Classifieds: Cars/Parts for sale/wanted
=> Collectables and Memorabelia
Reproduced Parts Information
=> What parts would you like reproduced?
Previous years Events
=> Events 2023
=> Events 2022
=> Events 2021
=> Events 2020
=> Events 2019
=> Events 2018
=> Events 2017
=> Events 2016
=> Events 2015
=> Events 2014
=> Events 2013
=> Events 2012
=> Events 2011
=> Events 2010
Archive from MSN Forum 2002 - 2008
=> Events 2008
=> Archive from MSN Forum 2008
=> Archive from MSN Forum 2007
=> Archive from MSN Forum 2006
=> Archive from MSN Forum 2005
=> Archive from MSN Forum 2004
=> Archive from MSN Forum 2002 - 2003
Loading...
