April 25, 2024, 01:51:26 PM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
: 2024 Events Calendar
http://www.betaboyz.myzen.co.uk/forum/index.php?board=92.0
Home
Help
Contact Admin
Search
Calendar
Gallery
Articles
Login
Register
General Category
Members Cars
Volumex Fuel Injected Montecarlo
Pages:
1
2
3
« previous
next »
Author
Topic: Volumex Fuel Injected Montecarlo (Read 31742 times)
Ammy
Offline
United Kingdom
Re: Volumex Fuel Injected Montecarlo
Reply #40 on:
July 01, 2016, 08:51:56 PM »
The only thing I recognise is the "cam-box" covers. Wonderful ! ! !
Offline
United Kingdom
Reply #41 on:
August 19, 2016, 07:27:02 AM »
So the car now has a LOT of new wire and is very soon off to the Rolling Road now it has a working Link G4+ Fury ECU. I did not finish the Traction Control and I will now leave that until after the 3000 mile Turin trip with the Monte Consortium in mid September. I need the CNC shop to finish the trigger rings for the front hubs and I have to fabricate brackets for the Vauxhall Astra Crank sensors that act as signal pickups.
I am looking forward to using the Toucan sensor information display and just being able to drive the car again after so much change. A couple of pictures to entertain:
Hawk
Offline
England
Reply #42 on:
August 19, 2016, 09:42:00 AM »
mmmm nice
Offline
United Kingdom
Reply #43 on:
March 28, 2018, 11:17:18 AM »
So Now the car has some new paint roll on Goodwood.
Offline
United Kingdom
Reply #44 on:
February 23, 2020, 08:16:38 PM »
Super impressive work Eric. Bravo.
How did you get on with the 10:1 compression pistons? I’m looking into having some pistons made this year but wasn’t planning on changing the compression significantly, if at all.
Did the dyno yield good gains?
Offline
United Kingdom
Reply #45 on:
February 24, 2020, 09:08:36 AM »
Hi Ian
Higher compression needs more control over ignition, consistent use of high octane fuel and the Cometic MLS gasket and ARP studs I use. I see around 300 BHP and 270 ft lbs of torque. It is frankly too much without great throttle control. If you build in turbo type mapped ignition with a sensor on the carb throttle spindle and better knock sensors as I have fitted it will make for a quick VX that does not die from detonation.
Offline
United Kingdom
Reply #46 on:
February 24, 2020, 05:28:34 PM »
Thanks Eric,
I thought it might be a little tricky controlling detonation with those boost+compression levels.
I’m currently on 9 psi with 8.5:1 and have the max advance held back to 29 degrees (+/-2 degrees flutter) or the detonation creeps in.
The new bottom end I intend building this year will be much the same as the current one but with forged pistons/rods, oil jets squirting from the main bearing caps like the fiat 1.2/1.4 16v engines and trigger wheel/sensor mounts for programmable ignition initially then ultimately FI.
So to keep it simple I think the current compression mark is a safe bet.
Do you have a preferred piston manufacturer?
Offline
United Kingdom
Reply #47 on:
February 25, 2020, 05:08:44 PM »
Hi Ian
My pistons came from Guy Croft and were made by JE to his design parameters. I also have Cunningham Forged Rods in this engine which have oil spray to the pistons via grooves in the rod cheeks. No Oil Jet install required. If you fit mapped ignition from the start that has load via a map sensor you can dynamically back off the advance and get benefit from 10:1 pistons. Obviously having Knock sensors and water/ air temp is even better. I fitted a pair on the exhaust side of the block.
Anything you can do to reduce induction heat is a winner so no metal box on top of the engine picking up heat and no heated inlet manifold.
Be aware FI on these engines is very tricky because of the airflow in balance. This is why I have the ECU I do and the Cam Phase sensor adapted from an Integrale for sequential ignition. DCOEs and DCNFs mask the problem at the expense of fuel economy.
Enjoy
Offline
United Kingdom
Reply #48 on:
February 28, 2020, 11:55:30 AM »
Thanks Eric, some very good food for thought there to help me decide which direction to go on several aspects.
I like the thought of a knock sensor but thought it might be difficult to achieve properly.
Air/water/manifold and ambient pressure/T-pos sensors etc are a given imo. Will have to see how best to achieve knock installation.
Still considering a DCOE double throttle body type injection system for simplicity but I realise there are pros and cons to this setup.
Thanks again for the info.
Offline
United Kingdom
Reply #49 on:
January 22, 2022, 06:43:20 PM »
Hi Folks
I am working away quietly on getting Electric AC into my Monte before heading to Turin in September this year. Slight understatement "this is a little complex" One of the elements is the Radiator with AC Condenser. The Monte original is not well suited to modern AC gas.
The Condenser comes from Car Builder solutions as does the core AC Heater unit. The Electric AC Compressor from Australia. I had 2 radiators made is it takes months to get this done so a spare was essential.
Enjoy
Pages:
1
2
3
« previous
next »
Please select a destination:
WELCOME TO THE LANCIA BETA FORUM - READ THIS FIRST
=> Welcome Message
=> Forum Rules, FAQs and basic user guides
=> Feedback and recomendations for the forum
General Category
=> New members
=> Members Cars
=> Back in the day
=> General Discussion
=> Group Buys
=> Off Topic
=> Betas in the Press
=> Events 2024
Technical stuff
=> Part Number Requests
=> Engine
=> Transmission
=> Fuel System Carb
=> Fuel System Injection
=> Fuel System VX
=> Heating/Cooling
=> Exhaust System
=> Ignition
=> Brakes
=> Electrical
=> Suspension
=> Steering
=> Wheels/Tyres
=> Interior
=> Manuals / Spec sheets
=> Body
=> Tuning and competition
Keeping your Beta on the road
=> Specialist Lancia Garages
=> Lancia Friendly Companies
=> Owners Useful Tips
Classifieds: Cars/Parts for sale/wanted
=> Collectables and Memorabelia
Reproduced Parts Information
=> What parts would you like reproduced?
Previous years Events
=> Events 2023
=> Events 2022
=> Events 2021
=> Events 2020
=> Events 2019
=> Events 2018
=> Events 2017
=> Events 2016
=> Events 2015
=> Events 2014
=> Events 2013
=> Events 2012
=> Events 2011
=> Events 2010
Archive from MSN Forum 2002 - 2008
=> Events 2008
=> Archive from MSN Forum 2008
=> Archive from MSN Forum 2007
=> Archive from MSN Forum 2006
=> Archive from MSN Forum 2005
=> Archive from MSN Forum 2004
=> Archive from MSN Forum 2002 - 2003
Loading...
