April 23, 2019, 02:12:50 AM *
News: 2019 Calendar of events: http://www.betaboyz.myzen.co.uk/forum/index.php?board=87.0
Author Topic: Engine Dampers - Alternative parts  (Read 40289 times)
« on: September 10, 2012, 12:06:43 PM »
If you want to replace your failed engine dampers you can purchase from the following sites:
Cam Belt (R.H) side Engine Damper OE Part Number: 82323829
http://faparkes.epicoriscala.com/Default.aspx
FA Parkes Stock Code: 42787
Supplier stock code is: 2611YY
Use the Search facility and use the Supplier (Stabilus) Stock Code 2611YY as the criteria.
Gearbox (L.H) side Engine Damper OE Part Number: 82323831
Use Ebay and search under item number: 250836085717
http://www.ebay.co.uk/itm/MERCEDES-200-300-C-E-G300-DIESEL-ENGINE-BELT-DAMPER-/250836085717?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3a66feebd5&_uhb=1#ht_2130wt_922
The only modification you have to make is to drill out the damper mounting bushes from M8 to M10 - This can be done with a SHARP 10mm drill bit and a decent drill.  Let the ally bush cool after 30 seconds of drilling and repeat until you have drilled right through the bush.
« Last Edit: September 13, 2012, 09:31:26 AM by MattNoVAT » Logged
Understeer is when you hit the wall with the front of the car. Oversteer is when you hit the wall with the back of the car. Horsepower is how fast you hit the wall and torque is how far you send the wall across the field once youve hit it.
KrissEB
Poland Poland
« Reply #1 on: May 13, 2014, 09:38:06 PM »
Matt please tell me is this solution works?
I'm asking because i find in Poland this part and in description is that
this dampers have strenght 900N (Myele) and 1200N (Swag).
Is this enaugh to use this in Beta?
« Last Edit: May 13, 2014, 09:52:54 PM by KrissEB » Logged
Lancia Kappa 2,0 16v
Lancia Y10 Avenue 1,1
Lancia Beta HPE 2,0
« Reply #2 on: May 14, 2014, 05:41:00 AM »
Yes,  I have these fitted to my S2/FL and have had no issues.
There were approximately 26 other forum members that used these when I did the "group buy" so maybe others who have fitted them can provide some feedback (if they have actually fit them that is)  Grin
KrissEB
Poland Poland
« Reply #3 on: May 14, 2014, 07:49:49 AM »
Thanks Matt - it's great news Cheesy
Thaks for your stuborn and patience in research:)
Lancia Beta HPE 2,0
1979 1300 Coupe 1983 2000ie Coupe
« Reply #4 on: May 14, 2014, 08:52:00 PM »
Yes, I had the dampers fitted while the CV boots were being changed for the MOT. Both old dampers were seized solid. The new ones made a noticable difference to drivability. They had to be packed out with washers as the bushings are narrower that on the originals.
I had drilled them out as above, but it took ages with my DIY drill & admittedly cheap drill bits.
