Title: petrol/temp gauges Post by: joe1999 on October 06, 2010, 08:47:30 AM Having an issue with my temp and petrol gauges. This started when I installed a new speedo cable I ended up removing the fuse box to get better access to the fire wall now the 2 gauges no long work though the temp gauge does go sparodically
Any ideas anybody? Cheers Title: Re: petrol/temp gauges Post by: thecolonel on October 06, 2010, 12:05:49 PM Not sure if it's a fused circuit (don't think so) but check fuses anyway.
presume you removed the binnacle to change cable so more likely one of the dash plugs is not located fully (hence intermittent operation) Geoff Title: Re: petrol/temp gauges Post by: joe1999 on October 07, 2010, 02:17:39 AM Cheers. I have checked all fuses no issues. By binnicle I awsume you are talking about the dash clocks and gauge assembly! have had this out a few times found no issues with the plugs or sockets but wil have another look
Title: Re: petrol/temp gauges Post by: thecolonel on October 07, 2010, 06:04:20 PM temp and fuel will share a common positive feed as they are both earth circuits (sensor/sender earths gauge)
once clocks are out check the plastic/copper circuit board for damage, trace the supply back to the plug then check plug for feed. |
