Technical stuff => Body => Topic started by: HFStuart on May 31, 2010, 11:46:28 PM
Title: Captive nuts for subframe
Post by: HFStuart on May 31, 2010, 11:46:28 PM
The captive nuts used to hold the subrame to the body, usually once the subframe is in place the bolts go in pretty easily but at the moment I can't get one to catch in the nut threads.
Is there a way to get at these? - I've a nasty suspicion one of mine at the back of the subframe has made a bid for freedom and isn't captive any more.
Title: Re: Captive nuts for subframe
Post by: thecolonel on June 01, 2010, 11:10:28 AM
In the past I have used a modified bolt as a stud.
Screwed it in first then jacked the subframe up to it.
I put a weld on the side of the bolt to stop it going
through the captivated nut.
Hope that heps.
Geoff
Post by: HFStuart on June 01, 2010, 01:09:49 PM
That sounds like a plan before attacking the housing - thanks.
NB Replacing brake pipes on a Spider  - not a job I want to do again in a hurry unless the engine is out !
Stuart
