Technical stuff => Electrical => Topic started by: Clifford on July 05, 2022, 04:19:25 PM
Title: Carello headlight rubber connector covers
Post by: Clifford on July 05, 2022, 04:19:25 PM
Hi all
On my series 2 f/l spyder when I remove the hard plastic protector caps off the rear of the Carello headlights the H4 lights have rubber boots on them that have slits for the bulb's male terminal posts to poke through to enable the female connectors to be pushed onto them. However,  the H1 lights don't have rubber boots on them when the plastic caps are removed.
Is anyone able to advise the following please?
1 Are the H1 lights supposed to have rubber boots? I suspect they do and have got lost over the years.
2 what is the Carello part number for the boots which is usually de-bossed in the rubber.
Many thanks
C
Title: Re: Carello headlight rubber connector covers
Post by: frankxhv773t on July 07, 2022, 11:38:10 AM
If they are like this the number is 03674509 but I have seen all sorts of variations though some are probably for other manufacturers lights.
Post by: Clifford on July 07, 2022, 04:32:11 PM
Thanks Frank.
I have 2 of these on the H4 lights (3 slits for the connectors) but there are none covering the backs of the other 2 lights which are H1 and I would expect 1 slit.
C
