Technical stuff => Steering => Topic started by: tenio hf on March 19, 2022, 06:17:10 PM
Title: steering rack damper
Post by: tenio hf on March 19, 2022, 06:17:10 PM
Good evening.
Following the advice of my colleagues in the forum, I solved the problem with the steering rack damper in this way.
Original Stabilus damper for Audi B series 80 with mechanical rack for 60 levs, which is about 25 pounds, 70 millimeters long and an ear on both sides. Laser cut plate of 6 millimeters of ordinary steel. Curved by hand;) with the required shape. The longer length of the new damper is not a problem, it is taken from our rails as seen in the photos, and the power of the new damper I think is close to the original 800 Nm.
Here is how it turned out:
(https://pichost.name/images/2022/03/19/5af610a5969426671fff381c0367eaf4.md.jpg) (https://pichost.name/image/q3xCA)
https://pichost.name/album/Z0bgz
https://pichost.name/album/Z0nS3
https://pichost.name/album/ZG6JT
https://pichost.name/album/Z0eCt
Title: Re: steering rack damper
Post by: peteracs on March 19, 2022, 07:08:31 PM
Good solution would you make the plate available to buy or the cutting details/drawing?
I think this would help some folk here
Also do you have a part nos for the damper?
Post by: tenio hf on March 19, 2022, 07:35:27 PM
I will ask the company that cut the plate for the laser file and I will try to upload it. Tomorrow I will take a picture of the new damper and the picture with the manufacturer's number will be uploaded here.
Post by: peteracs on March 20, 2022, 07:30:00 AM
Thanks, that would be most useful.
I was lucky enough to buy two new old stock original dampers, but know they one of those parts which you cannot find and I remember Matt on here spending some time looking into replacements. This sounds like a good long term solution.
One issue I remember from Matt was the throw of the damper, how does the Audi one compare to the original one?
Post by: tenio hf on March 20, 2022, 12:40:45 PM
(https://pichost.name/images/2022/03/20/f9501e2823ca050cc414e5df59012623.md.jpg) (https://pichost.name/image/q3Vb8)
(https://pichost.name/images/2022/03/20/27cced1e9d5cde1e733d5aa14464a2b0.md.jpg) (https://pichost.name/image/q3sLb)
This is the Stabilus damper number.
The drawing, which is designed on autocat, promised to send it to me by e-mail tomorrow and I will upload it here.
Post by: tenio hf on March 21, 2022, 07:46:22 AM
https://dox.abv.bg/user/myfolders?t=1647848742666
Post by: tenio hf on March 21, 2022, 07:54:56 AM
Good day.
In the above post I have given a link to my mail
in which I save the drawing file for the board
which I used to mount the longer damper.
I hope I have been helpful to someone.
Tenyo.
Post by: HFStuart on March 21, 2022, 09:08:48 AM
Great work!
Post by: peteracs on March 21, 2022, 09:17:53 AM
Hi Tenyo
Thanks for that, you mention that you bent the plate, I am curious was this due to clearance problems or would a spacer do the same job and avoid the bending?
Post by: tenio hf on March 21, 2022, 10:33:05 AM
Hi Peter.
Bending of the plate can be avoided by placing a 10.00 mm bushing between the damper and the plate and a longer bolt. But in this case, I decided that I wanted to bend the plate and I think it worked out well. Bending is necessary because the damper tank rests on the plate when the rail is moving.
