Technical stuff => Interior => Topic started by: capriblu on February 10, 2021, 03:09:46 PM
Title: Coupe FL Front Seat Upholstery Interchangeability L/R
Post by: capriblu on February 10, 2021, 03:09:46 PM
The interior of my 2nd series F/L coupe is pretty good apart from general signs of wear on drivers (R/H) seat pad.
Whilst the L/H v R/H front seats are physically different are the upholstered parts i.e. seat pads and backs interchangeable?   In other words if I find a matching material L/H front seat can I easily swap the material pads to replace those on a R/H seat frame?
Title: Re: Coupe FL Front Seat Upholstery Interchangeability L/R
Post by: Nigel on February 10, 2021, 06:16:16 PM
Hi capri,
From what i've seen on both 1980 and 84 HPE's, you should be fine with that.
As far as I can tell, only the tilt/release mechanism and the fore/aft runners are handed.
And, generally, a L/H seat is likely to have less wear, but looks like you thought of that already.
Regards, Nigel
Post by: capriblu on February 10, 2021, 11:20:41 PM
Thanks Nigel,
Yes just wanting to put the upholstered base and maybe back from a L/H passenger frame onto R/H driver side frame.  Should be doable I think.
Thanks,
Andrew
