Technical stuff => Wheels/Tyres => Topic started by: Fulvia 3 on November 20, 2015, 01:19:41 PM
Title: Tyre Pressure for HPE
Post by: Fulvia 3 on November 20, 2015, 01:19:41 PM
Happy owner of a 1978 HPE 1600 since last month.
According to my Instruction Book, inflation pressure should be 24 psi !!
[27 psi when full loaded and 28 full loaded and constant high speed.]
According to a 1976 North American specs Instruction Book, inflation pressure is 28 psi (sounds logical).
For the first month I tried 27 psi and she drives nice. I cannot persuade myself to try 24 ....
What is your experience on the subject?
Thank you,
M
Title: Re: Tyre Pressure for HPE
Post by: HFStuart on November 20, 2015, 02:01:28 PM
Maybe 24 on the back when empty but seems too low.
What tyre size?
I run 185/65 14 with 29psi all round (in a spider) and it works well.
Post by: smithymc on November 20, 2015, 02:24:02 PM
My handbook says the same for the coupe - I now run 26 all round one or two up on standard tyres.
Post by: Fulvia 3 on November 20, 2015, 03:24:30 PM
What tyre size?
175/70-14
Post by: HFStuart on November 20, 2015, 08:17:35 PM
Reckon 27 all round would be about right then.
Post by: Neil-yaj396 on November 21, 2015, 09:05:50 AM
The pressures in the handbooks always seem to be on the low side by up to date standards.
Post by: lbcoupe76 on November 21, 2015, 10:14:29 AM
You have to take into consideration that every tyre manufacturer will have different sidewall construction and therefore different pressures. Tyres have changed a lot since those tyre placards where written. Look up the rule of four for tyre pressure, this works well. if you can't find it i will type it out for you.
Post by: peteracs on November 21, 2015, 12:07:20 PM
Good call, I had forgotten about that. Here is what appears to be a good write up
http://cdn2.hubspot.net/hub/210453/file-20229690-pdf/docs/importance_of_optimum_tyre_pressure_and_temperature.pdf (http://cdn2.hubspot.net/hub/210453/file-20229690-pdf/docs/importance_of_optimum_tyre_pressure_and_temperature.pdf)
