Technical stuff => Interior => Topic started by: aldad138 on November 03, 2015, 08:09:07 PM
Title: Rear Should Belt Retrofit in 79 Beta Coupe
Post by: aldad138 on November 03, 2015, 08:09:07 PM
Hello again!  I am hoping some of you fine folk have experience and pictures with installing a three point seat belt in the back of a Coupe.  My 79 has lap belts only, and I have sourced good aftermarket "universal" seat belts.  I am hoping to get some lessons learned from anyone that has already done this.  Biggest two questions are:
Ideal top mounting position for the shoulder "hook" and ideal mounting location for the retractor down near the floor.
Thanks!
Title: Re: Rear Should Belt Retrofit in 79 Beta Coupe
Post by: lbcoupe76 on November 04, 2015, 12:27:58 AM
Not the best pics but should show you where they attach. Hope it helps.
Post by: Neil-yaj396 on November 04, 2015, 07:26:18 AM
All the anchor points are there (factory drilled and threaded) , you just need to uncover them and remove any grommets filling the holes.
Your fitting bolts will obviously need to be a matching thread. If the thread has gone on the lower points it's possible to fit retaining nuts via the rear wheel arch/under the car.
Post by: aldad138 on November 10, 2015, 12:24:19 AM
Thanks!  This is great information.
Alex
Post by: aldad138 on December 16, 2015, 04:42:30 PM
 We got Wesco top mount retractor rear shoulder belts in!  A bit of fabbing for a mounting bracket, and voila!  I recommend their products if you need rear shoulder belts.
