Technical stuff => Transmission => Topic started by: rossocorsa on November 02, 2015, 10:31:59 PM
Title: driveshaft support bearing spec
Post by: rossocorsa on November 02, 2015, 10:31:59 PM
just in the middle of changing the shaft support bearing, I got the replacement bearing from Mark and it's C3 tolerance however the one that I've removed (and superficially seems original) is standard tolerance anyine know which it should be?
Title: Re: driveshaft support bearing spec
Post by: HFStuart on November 02, 2015, 10:53:46 PM
Alan,
C3 bearings are routinely used in applications where a standard one could be used - it's the other way around where you might run into problems. It's quite possible Lancia fitted both.
Stuart
Post by: rossocorsa on November 02, 2015, 10:58:42 PM
Thanks I realise there's not a huge difference but you know I'm a terminal pedant
Post by: HFStuart on November 03, 2015, 08:01:00 PM
I has been noted on occasion, yes ;)
