Technical stuff => Ignition => Topic started by: Hurrying Pete on February 12, 2014, 11:34:40 PM
Title: Ignition Switch Failure
Post by: Hurrying Pete on February 12, 2014, 11:34:40 PM
The ignition Switch on my VX Coupe has failed.  It will switch on the starter motor but does not power up the other electrics.  Have stripped the switch down to a riveted plastic assembly with 5 wires coming from it.  If I drill out the rivets goodness knows if it is repairable or if I could reassemble it.  The only switch I can find in the UK is for a Monte Carlo but the has a 4 wire loom.  Are these switches still available in Italy?
Title: Re: Ignition Switch Failure
Post by: thecolonel on February 14, 2014, 08:23:13 PM
Saw your post on lmc but can't post there.
I have a spare for the gamma which is five wire,
 same era, so should fit.
Geoff
Post by: Hurrying Pete on February 15, 2014, 12:02:39 AM
Hi Geoff, that sounds great.  Much relieved, let me know your price.
Post by: mtulloch on February 16, 2014, 10:24:49 PM
http://www.ebay.co.uk/itm/LANCIA-BETA-IGNITION-LOCK-ASSEMBLY-/231160412124 (http://www.ebay.co.uk/itm/LANCIA-BETA-IGNITION-LOCK-ASSEMBLY-/231160412124)
Might be worth a punt!
Post by: Hurrying Pete on March 03, 2014, 09:57:43 PM
Sadly Geoff's kind offer proved that Beta & Gamma have different switches.  I looked at that used one on Ebay & found that a new one had also appeared on there.  I bid on the new one, got it & the VX is back on the road.
