Technical stuff => Transmission => Topic started by: glovebeast on December 29, 2012, 05:56:46 PM
Title: Inboard CV joint re-assembly
Post by: glovebeast on December 29, 2012, 05:56:46 PM
I've removed the in-board CV joint in order to replace both inner and outer boots. There is a washer that goes on the splined shaft before the CV joint; Haynes and the Fiat manuals just describe it as a washer, but mine are dished.
1. is this correct
2. if so, which way should it face?
TIA
Steve
BTW car is a Volumex HPE
Title: Re: Inboard CV joint re-assembly
Post by: WestonE on December 30, 2012, 10:46:01 AM
The dome should be towards the joint it is just putting some spring load into the assembly to stop it shuttling on the spline.
Post by: glovebeast on December 31, 2012, 01:04:43 PM
Thanks Eric - I'll re-assemble later today
Happy New Year!!
