Technical stuff => Fuel System Carb => Topic started by: The_Matrix_Master on August 25, 2022, 08:07:20 AM
Title: 34 DMTR ~ Electrical connection ?
Post by: The_Matrix_Master on August 25, 2022, 08:07:20 AM
Help /info Please
There is a short electrical cable circa 20 cm with a male spade terminal at the back of the Weber 34 DMTR Carburetor
Clearly it should be connected to somewhere in the engine bay but I cannot see where ?
Where does it connect to and what is its function?
Title: Re: 34 DMTR ~ Electrical connection ?
Post by: peteracs on August 25, 2022, 09:34:26 AM
Sounds like the fuel cutoff solenoid. Check the wiring diagram where on your car where it connects to on the loom
Post by: JohnFol on August 25, 2022, 10:22:11 AM
and from memory it connects to the +ve of the coil
Post by: peteracs on August 25, 2022, 11:12:35 AM
Hi John
Sounds about right as it is a red wire from memory on mine.
Post by: The_Matrix_Master on August 25, 2022, 05:50:02 PM
Such a small cable in length so have been trying to find a similar size female spade terminal around the carbs location but nothing visable
Carb seems to be sucking a bit to much air on idle and appears erratic anything from 700 to 1100 rpm , carb fine under load so was  wondering if this was down to the unconectted wire ?
Post by: JohnFol on August 25, 2022, 06:24:21 PM
A bit from memory but from shut off device on carb, the red wire joins a plastic covered connector (about 20cm). The other side of the connector joins the loom near starter and pops out near the coil.
Not sure it would be related as it just shuts fuel off or not.
If you put 12v on the spade connector you should hear it click, and again when removing 12v
Post by: JohnFol on September 02, 2022, 10:12:19 AM
This is how it connects
Post by: The_Matrix_Master on September 02, 2022, 10:34:05 AM
Cheers John
